Chevy 216 help! Cant go over 50 mph
Discussion in 'The Hokey Ass Message Board' started by kmiele, Mar 25, 2010.
  1. kmiele
    kmiele
    So i finally found the cause of my problem and to you old school guys who know points like the back of your hand its gonna sound like im an idiot... But i am a younger mechanic used to fuel injection... The spring on the points was missing, i thought the copper strip that connects to the stud in the distributor also supplied the needed tension to keep the points on the cam but obviously not. The points were floating. Thanks guys for all the input and i can finally run down the road with the rest of the traffic!
  2. RUFTOY
    RUFTOY
    I had the exact same problem with a FORD. The same RPM in every gear.
    Turned out to be the spring tention on the points. They started foating at that RPM.
    I bent the spring arm to give them a nice snap closing and all was well after that.
    Good luck.
    Larry
  3. pistoncan
    pistoncan
    from Missouri
    See, I told ya it would be something simple that we hadn't even thought of, and impossible to guess at from a distance. Im just glad you figured it out and you are up and running now. Thats one you never will forget.
    Gary
  4. budd
    budd
    well i'm a little confused, how did you adjust the point gap when you installed them?
  5. 29nash
    29nash
    from colorado
    Back here on post 23, you caught the scent!! only a matter of time after that!!
    Good on you. For actually figuring that out. It means you pay attention and eliminate.......... Hey, that was one of my guesses! Point dwell; at high rpm your point dwell was zero...............ha.
    The other upside is now you have a story to tell your grandkids. I suggest you jot down a summary of this event and store it.
    I'm not confused. It's pretty obvious what happened, now that OP has found the problem........... and any one of us could have missed that.
    Babbitt ponder? That’s a myth, parroted by people that just don’t know.
    Babbitt bearings, if worn out, they knock just like any bearing will, but otherwise they are the same, durability-wise, as insert bearings. The downside isn’t the Babbitt bearings, it's the splash and dip and gravity feed oiling. On a race track constant centrifugal force caused the oil to spill out of the rod dipper trays and the main reservoir cavities, starving the bearings.
    Driven in normal conditions on the road the motors give good service. I’ve had two stove bolts, a ‘31 & ‘51 that I drove at highway speeds all day long, 55-65, which was wide open in the case of the '31 because it had 411 rear gears.
  6. burnout2614
    burnout2614
    dang, I was sure it was a defective front roll-over valve! peace
  7. burnout2614
    burnout2614
    It's cool that you know how to use a timing light, most younger guys have never seen one!
  8. kmiele
    kmiele
    Yeah i have never had to use one at work, but i have seen them and do know what they are for, haha...
  9. pistoncan
    pistoncan
    from Missouri
    I imagine the copper strap gaive it enough tension to open them stationary but not enough when running. Being a tenderfoot he wouldn;t know there should be a steel spring too. But he will never forget it now.
  10. JOECOOL
    JOECOOL
    If it was easy ,everybody could do it, this stuff builds character, patience,and makes you a better hot rodder.
  11. flynbrian48
    flynbrian48
    How much faster do you expect that babbit bearing'd 216 to go? 50 mph is cruising speed for it. While in good tune it'll push the car to 75 or 80 (briefly), it's not going to be comfortable doing that all day. It may just be tired enough that it's just not gonna wind up any faster.
    Or, I could have read the entire post and seen that you'd fixed the problem. Duh...
  12. Hnstray
    Hnstray
    from Quincy, IL
    I would check inside the distributor very carefully.......the wire that leads from the breaker plate to the distributor and the wire from the points............I had a problem years ago that involved one of these two...can't remember which,.........but when the breaker plate rotated was rotated for spark advance it grounded the wire with similar results. The insulation is likely old and cracked, or missing, and is often overlooked because it sometime is blocked from view by other dist parts. Worth checking.
    Ray
  13. plym_46
    plym_46
    from central NY
    How did the spring get set aside?
    90% of all fuel problems are ignition related, and 90% of all ignition problems are fuel related.
    Hence a good troubleshooting flow chart followed along it steps will isolate the problem.
    Most of the old MOTORS manuals will have a trouble shooting guide as part of the introduction. Since most of us have now gotten used to the typical look up the code and start replacing parts, the old tried and true troubleshooting procedures have been tosed out with the defective MAP sensor.
    Finding one reading it and keeping it handy is a good idea for anyone going back to pre OBD days.
    As to the comment above, I had a similar problem, finally pulled the wire ad found some bad isulation allowing it to short out against the dizzy body. I fixed it by winding it with some fine silk thread, and a coating of thinned rubber cement.
    Another hady tool is a vacuum gauge, a simple way to learn alot about the conditio of your engine. Amazing tool check the scenarios here
    http://www.secondchancegarage.com/public/186.cfm
  14. kmiele
    kmiele
    Actually the car goes down the highway pretty good now that the problem is fixed, as for the setting the points question, the brass strip did give it enough tension to set the points, the spring was a seperate piece and when i ordered the new points they came with the spring. I didnt replace the points the first time, the guy i bought the car off of did, so they were new when i looked at them which is why i didnt suspect them as the problem.
  15. bullyb
    bullyb
    from Hawaii
    try checking the intake manifold connection to the cyl. head
  16. kmiele
    kmiele
    As i said in the last post the problem is fixed, but thanks for the info
  17. 39 chevy kustom
    39 chevy kustom
    bullyb try reading the entire post , also try posting an intro. before posting on threads you haven't read entirely.
