chevy 216 oiling system help
Discussion in 'The Hokey Ass Message Board' started by hbomb60, Jul 29, 2006.
  1. hbomb60
    hbomb60
    from Minnesota
    Im trying to put fenton headers on my 216 chevy 6 cyl. The problem is that the oil filter is attached to the block, with no oil lines to and from the filter housing The p***ages are in the attachement to the block. How do you relocate this filtering system to work with the fentons? Any experiences with these.
    thanks
  2. GamblinAJ
    GamblinAJ
    from Corona Ca
    Well I have no experiance with the oil filter and my Fentons, but did have have one with my throtle linkage. The Fentons seem to be made mainly for a dual carb set up and on my 216 I have a single carb(don't think the 216 could handel 2 carbs) So before you start trying to relocate everything check the throtle linkage. I decided to just split my manifold rather then rig a seconed bell crank and re route everything for that ****y 216. I will wait to use the fentons till I get me a 235 with dual carbs. So save yourself the missery and eyeball it first. Good luck.
  3. squirrel
    I'd like to see a picture of an oil filter mounted to a 216 without any oil lines.
  4. Same here. All of them I've ever seen have been mounted to the intake or firewall. Or they don't have one at all.
  5. 302GMC
    302GMC
    from Idaho
    This filter setup takes the place of the oil distributor found under the little kidney shaped 3 screw plate. If I remember correctly, it uses a roll of toilet paper for an element. It's a byp*** system like the AC & Fram add-on units. I'd remove it and replace the original innards, then plumb in a spin-on adaptor mounted out of the way.
  6. squirrel
    I kind of figured that's what it might be...thanks for the explanation.
  7. hbomb60
    hbomb60
    from Minnesota
    I can get pics tomorrow when I go back to the shop. It has an integreated inlet and return in the housing of the filter. Thats what bolts to the lower side of the block. There is a inlet, outlet, and a spring loaded valve under where the filter housing mounts to the engine. No lines. There is a br*** oil line that runs from the mount on the block for the oil filter to the same side of the block, but higher up the engine. Maybe into another oil p***age?
  8. hbomb60
    hbomb60
    from Minnesota
    Can I just block off that 3 screw portion and put a twist on adapter in the br*** oil line comming out of it?
  9. 302GMC
    302GMC
    from Idaho
    There's a valve underneath the cover that must be replaced for correct oil distribution. It has to be there in order for oil to get where it has to go. I'd use the whole ***'y out of a parts engine, then use the hose fittings in the block same as an AC or Fram setup.
  10. hbomb60
    hbomb60
    from Minnesota
    Will this setup be the same on a 235? Or is this specific to the 216?
  11. squirrel
    it was only used on the splash engines, so look for one from a 216. The later engines did not have the oiling cover on the side of the block.
  12. Crosley
    Crosley
    from Aridzona
    interesting.... I never knew of a block mounted filter of any type on the 216 splash oiled motor.
    I've run a couple of 235 motors that I modified for full pressure oil filter
  13. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The filter that bolts directly to the block is an aluminum aftermarket piece that was sold by Inner Line. I've seen a few of them at swap meets.
