Technical chevy 235 camshaft
Discussion in 'The Hokey Ass Message Board' started by Mario p herrera, Mar 20, 2021.
  1. Mario p herrera
    Mario p herrera
    Does anybody make a mild camshaft for a 57 chevy 235 straight 6 thank you in advance
  2. sunbeam
    sunbeam
    Elgin E293-S It is a solid lifter cam finding good hydraulic lifters is tuff. It is about the same as the Corvette cam.
    Mario p herrera likes this.
  3. Switch to solid lifters and go with a corvette grind. Works very well.
    like sunbeam said, the new hydraulic lifters seem to be problematic.
  4. 6-bangertim
    6-bangertim
    Later 235's use the same grind as the 261. There seems to be a shortage of 235 cam blanks for new grinds, so you'll need to use YOUR cam for a regrind. I have a couple used, good, cams I'd part with - send me a PM.
    Tom Langdon at Stovebolt Enging Co. has a 'Bulldog' grind that seems to work well. All the current cam grinders can regrind your cam. My '57 is running a 220@.050 / .450" lift, idles well - even with the stock carb n intake! I like SCHNEIDER CAMS here in San Diego, lots of experience with vintage engines.
    Go with a SOLID grind, as there is no good Hyd. lifters available - unless you score a NOS set on ebay...
    tractorguy and Mario p herrera like this.
  5. Mario p herrera
    Mario p herrera
    Thank you guys will try a regrind
    6-bangertim likes this.
  6. I have some NOS & NORS lifters, what number should he look for? Dave
