Chevy 235 maybe?
Discussion in 'What's It Worth?' started by Mrchance, Nov 15, 2023.
  1. Mrchance
    Mrchance
    These are the best pics available, not sure what I'm looking at exactly 216/235, estate sale no one knows history. Looking for value if any and if it’s 235 IMG_5920.jpeg IMG_5919.jpeg IMG_5918.jpeg IMG_5917.jpeg IMG_5916.jpeg
  2. squirrel
    that engine is worth some money....not sure how much, but it's a 54 235 from what I can see, and it has some really neat old speed equipment on it.
  3. tractorguy
    tractorguy
    Doesn't matter.......BUY it. That is some rare intake setup and that valve cover is very rare and identical to the one some dirt bag stole out of my barn back in the mid 90's. Looks to be older 235 ? or more likely 216 with that style valve cover with the two hold down bolts in the center instead of four small "stovebolt" around the sides. Hopefully some folks much smarter than me will give better identification. Buy it. Have fun
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    on a 216 the side cover is taller and goes over the spark plugs, it is a 235
  5. squirrel
    The two studs to retain the valve cover was used through 54, even on the 235, eh? As mentioned, the side cover height is how you tell a 216 from a 235
  6. fastcar1953
    fastcar1953
    Babbit rod not full pressure 235. Yes it is a 235.
  7. Mrchance
    Mrchance
    My current 216 and this “235” will be the same oil splash system? I was looking to upgrade…..
  8. 302GMC
    302GMC
    from Idaho
    Only if it's a '50 - '52 Powerglide 235 ... '53 up are full pressure. Look for an oil distributor on the block under the headers. If it has one, it's babbit rods.
    Moriarity likes this.
  9. fastcar1953
    fastcar1953
    53 was splash oil unless powerglide. all 54 and up were full pressure.
  10. fordcragar
    fordcragar
    from Yakima WA.
    All of the speed equipment on that engine, including the valve cover, will fit on a 235ci engine up to 1962. That would be a score.
    54delray likes this.
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    3701481 is a 1954 block. It's definitely a fully pressurized oiling system, but uses the early style water pump, making it a good candidate for upgrading an earlier car that came with a 216.
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Also, you can't go by the two stud style valve cover; since all of the aluminum covers used that method of retention, lots of guys just replaced the two rocker bolts in the 1954-62 engines with the earlier studs so they could run a cool valve cover.
    54delray and Moriarity like this.
  13. fordcragar
    fordcragar
    from Yakima WA.
    What was the asking price for the engine? This engine would be an upgrade from a 216ci engine. It would have insert bearings.
  14. fordcragar
    fordcragar
    from Yakima WA.
    The valve cover and intake are probably worth that; which might be hard to find if you were looking for them. I couldn't tell in the pictures if it has headers on it.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    Oh my, get over there and get it before someone else does
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    Looks to me like it has chromed Fenton headers on it 0B1ECA83-F97B-42AD-A037-E5ABF1AA9C34.jpeg
  17. fordcragar
    fordcragar
    from Yakima WA.
    Then for $500, it is a deal.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    I would be surprised if it hasn't been sold already....
  19. KenC
    KenC
    Agree that it is a 54 with really neat equipment. The headers almost look like fabricated stainless as I think I see welds at the flanges. Either that or ground and polished cast iron. 500 is a deal!
  20. 325w
    325w
    By changing the 54 rocker hold down bolts to studs the 54 235 can use this valve cover. Neat old 6!
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    you got a smoking bargain on that, must not have been a very well publicized estate sale
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    I enlarged the pics, always select "full image" when posting... looks good. does it have chromed fenton cast iron headers on it?
  23. Mrchance
    Mrchance
    Thanks! The headers don’t say Fenton anywhere on them
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    they look like fentons to me, the name was probably polished off when they chromed em. they are chromed and cast iron right?
  25. Ruben Cruz
    Ruben Cruz
    This is correct listen to this guy, he knows exactly what he’s talking about
