Technical Chevy 235 squeking, not the belt
Discussion in 'The Hokey Ass Message Board' started by Kaptain Kustom, May 16, 2023.
  1. Kaptain Kustom
    Kaptain Kustom
    from Finland
    Hi,
    I have a '50 Chevy with a 261. There is a squeking noise coming from the front of the engine. It sounds just like a loose belt (which I thought it was for half a year, swapping belts, etc.) BUT the same noise is there even if I take the belt off.
    The noise is worst when engine is hot and idling. Especially with the gear on (auto trans). It does not shake excessively.
    I put a new gear set with aluminum cam gear in a couple of years ago when I had the engine apart. The crank pulley / balancer is an old one from a 235. Timing cover has an added check plug. I managed to squirt oil in via it; no effect on the noise.
    The engine was sounding normal for a year or two, and has squeled for a couple of months now. It has oil pressure.
    Does anyone have any ideas? It's driving me crazy.
  2. JohnLewis
    JohnLewis
    With the belt drive disconnected, the only thing spinning would be the cam and crank. I had a buddy complain of a squeaking in his motor. When we tore it down we found this. IMG_5661.JPG
    tractorguy, FishFry, SS327 and 2 others like this.
  3. BJR
    BJR
    Are the rocker arms in the front of the engine getting oil?
    tractorguy likes this.
  4. Budget36
    Budget36
    Cheap way to turn a journal I guess;)
    Hnstray likes this.
  5. wheeltramp brian
    wheeltramp brian
    Maybe see if you can squirt some oil at the front crank seal?
    jaracer likes this.
  6. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Could it be the distributor? Does yours have an oil cap on it? Just a thought.
    KK
  7. BJR
    BJR
    On the Y block forum they talk about the ring on the front crank damper coming loose and causing a squeak. I believe it moves and rubs on the timing chain cover. I know it's not a Y block but you may want to look at that also.
  8. Kaptain Kustom
    Kaptain Kustom
    from Finland
    Thank you all very much for your suggestions (also the frightening ones) !
    This one crossed my mind also earlier, but the area didn't seem dry, so I forgot it. However, seems like it really was something this simple and easy! Your comment made me consider it again and try it. Needless to say how relieved and happy I am. Thanks for your ingeniousness!
  9. flatheadpete
    flatheadpete
    from Burton, MI
    Nice! Happy you figured it out.
  10. wheeltramp brian
    wheeltramp brian
    Sweet very nice! Maybe time for a new front crank seal is that one may have dried out so much that is squeaking that bad even with oil being behind it
  11. jimmy six
    jimmy six
    It rubs on the front “steady rest” that bolts to the timing cover. I removed mine after I had the Damper Doctor repair the damper.
