Hot Rods Chevy 265 1955 number problem...
Discussion in 'The Hokey Ass Message Board' started by TheTumbleweeds, Sep 6, 2011.
  1. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    hi!
    I have a chevrolet small block 265 from 55. (no oilfilter) And it has a number in front, wich I think that tells what car and maybe tranny it had mounted.. can someone help me maybe?
    Number: 00II033GB
    Sorry about my bad spelling, im from sweden =)
    regards christian
    (cast date: A125)
  2. squirrel
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I had a 265 that I could not give away once. Turned out to be a replacement block that could be 265 or 283 if bored out, had no filter pad as well. No one wanted it becauce casting # or ser # ment nothing.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Hi guys!
    So I maybe have a early replacement block?
    I just love this engine, there is so many differents from 56 up.
    Im missing lots of connecting rods and pistons, Does chev 302 fit? Its the same stroke and bearing and tap size..?
    I figured out that the block is made 12th januari 1955 (A125)
    So, whats the deal with the distrubiter? Ive got a Mallory cris craft model, that i low buildt and a cool looking cap! Can I use that?
    thanks!
  6. Model A Vette
    Model A Vette
    One thing to remember is a notch that MUST be in the cam to oil the lifters correctly on a '55 engine.
  7. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    I´ll check if there is one! thanks again
  8. DenverDave
    DenverDave
    from Denver, CO
  9. squirrel
    The connecting rods from any 1955-1961 Chevy 265 or 283 should fit.
    You will need pistons for a 265, or you might be able to bore the block to 283 bore size (3.875) but you should get the block sonic checked to make sure the cylinder walls are thick enough.
  10. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    Hi! I've checked on the camshaft(witch is in good condition) a machined surface at the rearend! S274 marked as well..
    Im going to refresh my cylinders, and check and measure. I think it can be used with std bore..
