chevy 292 6 cylinder cam/crank gear oil tube
Discussion in 'The Hokey Ass Message Board' started by sprint69, May 1, 2011.
  1. sprint69
    sprint69
    <hr style="color: rgb(229, 229, 229); background-color: rgb(229, 229, 229);" size="1"> I'm not allowed on the Tech thread so here I am.
    I have a late model Chevy 292 straight 6 block casting number "93406004". There doesn't seem to be a hole in the block for the cam / crank gear oiling tube. The hole should be right above the crank gear.... correct????
    Confused & Thanks
    Jon
  2. CrkInsp
    CrkInsp
    from B.A. OK
    GM desided it is no longer required. They get enough lube by splash, they say.
  3. sprint69
    sprint69
    CrkInsp,
    Thanks for the info. Hope "they" know what they are talking about.
