Chevy 292 Made in Mexico Help
Discussion in 'The Hokey Ass Message Board' started by fleet_47, Jan 12, 2014.
  1. fleet_47
    fleet_47
    from N/A
    What years was the Chevy 292 engine made in mexico? Any links with decoding the numbers on the block?
  2. mashed
    mashed
    from 4077th
  3. squirrel
    the "crate replacement" engines were made in Mexico...Goodwrench....
  4. fleet_47
    fleet_47
    from N/A
    Any idea what year that started and ended, trying to get an idea what year this 292 is?
  5. CNC-Dude
    CNC-Dude
    They all have casting dates on them, just look on the block and see. Your at a dead end if your trying to locate any casting number info for the Mexican or Canadian blocks, only the blocks cast in the US have that info available.
  6. squirrel
    80s-90s would be my guess on production dates. I had one from the mid 80s.
  7. Snarl
    Snarl
    Pinning down the exact year of the block won't change anything regarding buying parts for it. Water pumps and thermostat housings changed over the years, and the first 2 years had smaller flywheel bolts and pins, but after 1980 none of that matters as 1980-89 are all the same.
  8. tlowe
    tlowe
    I agree, there is no need to narrow it down to a year, all the Mexican 292's are considered newer. Probably 1980 -89
    #'s are on the p*** side of block in casting. engine code and vin on dist pad.
  9. fleet_47
    fleet_47
    from N/A
    That was more concern, having to buy parts and not knowing the year of the engine. Thanks.
