Chevy 350 - Toploader Transmission
Discussion in 'The Hokey Ass Message Board' started by DeanoAZ, Jan 22, 2011.
  1. DeanoAZ
    DeanoAZ
    from Peoria, AZ
    Okay, this newbie has learned how to navigate HAMB and searched the archives for threads on this and couldn't find anything (can't believe it hasn't been done before). Looking for some direction on hooking up a Chevy 350 engine with a Ford Toploader transmission. Does anyone have some idea for finding the right pilot bearing for the 350 that will match up with the Toploader shaft? I know, for all you purists out there, the questions becomes "Why would anyone want to do that???". Free is always good!:D
  2. Relic Stew
    Relic Stew
    from Wisconsin
    Lakewood makes a ****ter shield bellhousing for that application. Not cheap though.
  3. 73RR
    73RR
    Fancy bell is not needed. Ford and GM have, essentially, the same length input shaft length. The difference will be the diameter of the bearing retainer vs. the bell opening. Once the registration is fixed then make new bolt holes.
    As to the pilot bearing, measure the input shaft on one of each and buy or make a new oil-lite bushing.
  4. Phil1934
    Phil1934
    Lakewood housing uses a pilot bearing 15975 with serrated edge that fits in crank flange.
  5. DeanoAZ
    DeanoAZ
    from Peoria, AZ
    Thanks a lot, Phil1934, that's just what I am looking for. Appreciate the comeback!
    :D:D:D
