chevy 4 wire alternator
Discussion in 'The Hokey Ass Message Board' started by duken, Aug 17, 2012.
  1. duken
    duken
    Hey Could really use some help I really want to take my 53 bell to the state take over and I'm still having problems with the alternator on my car its a chevy 4 wire and I know the two wire is better and easier but this is what I have and I already built the mount for it so its what I have to run any way I can get it to charge but when I do it wines I've read all the stuff about how to wire them and how you need a resitor in the the field wire so I tried that and to no avail still wines please help
  2. Commish
    Commish
    from NW Ok
    I am not sure what Alt. you are calling a 4 wire, might throw up a picture of it, or the Delco number. Just off the top of my head if it is whining loud it sounds like you have got the field shorted to full field it and it is putting out full capacity, that or your battery is real low and calling for a lot of amps.
  3. brokenspoke
    brokenspoke
    Check out "madelectrical" lots of excellent info
  4. duken
    duken
    Can,t figure out how to up load photo in thread but I got them up loaded to my album on here also I tried to in stall a 275 ohm resistor in the field wire and still whines like my kids
  5. duken
    duken
    figured out how to upload them
  6. d2_willys
    d2_willys
    from Kansas
    Sounds like your bearings are shot.
  7. Rusty O'Toole
    Rusty O'Toole
    Find an old Chev wiring diagram and wire it like the factory, it will work like factory. If it whines only when charging it could just be your battery is half dead. When the alternator is working real hard it makes the belt whine sort of like when the air conditioning kicks in. Check the fan belt, if it is not worn out and is adjusted right, shut the hood and go for a drive. You won't hear it if you turn up the radio. Seriously, when we are really looking at the motor with the hood up we hear lots of things that don't mean anything.
  8. 325w
    325w
    You only use two of the wires. But for the life of me I can't remember which ones . I think 1 an 3.
  9. themoose
    themoose
    Make sure you have an large enough gauge wire for engine ground and battery feed wire to the alternator.To small of a gauge will cause excessive resistance. As stated above a detective or low battery can also cause high resistance
  10. bohica2xo
    bohica2xo
    from Las Vegas
    That is a CS series alternator.
    Connect the "S" terminal in the plug (Larger wire on one end) to the battery. You can just loop it over to the output stud on the alternator.
    If you are using a warning lamp, connect one side of the lamp to switched +12v and the other side to the "L" terminal in the plug.
    If you are not using a warning lamp, use a 475 ohm 1/2 watt resistor between the "L" terminal and switched +12v
    B.
  11. duken
    duken
    cool i got it thanks for all the help
