Technical Chevy 400 smallblock identification
Discussion in 'The Hokey Ass Message Board' started by lemondana, Jan 29, 2025.
  1. lemondana
    lemondana
    from Lincoln NE
    Correct me if I'm wrong. I thought recently that someone was having a conservation regarding the 400 identification and casting numbers. Can someone point me in the right direction?
  2. 19Eddy30
    19Eddy30
    from VA
    Look @ side block , No help on codes,
    Bore 4-1/8
    Some have 3 freeze plug down each side , or 2 & 1 in middle ,place for but not drilled
    lumpy 63, Deuces, chevy57dude and 2 others like this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
  4. squirrel
    I don't recall any recent 400 ID threads.
  5. lemondana
    lemondana
    from Lincoln NE
    It could have been somewhere else. But thanks for any information anyway.
    Deuces likes this.
  6. Kerrynzl
    Kerrynzl
    https://www.mortec.com/castnum.htm
    lemondana likes this.
  7. nutnfits
    nutnfits
    I’ve had 3 of these engines. The casting number to look for is on the bell housing flange on the drivers side behind the head. All the 400s that I’ve had, that number ended with 511, known as the 511 block. The 511 blocks have 4 bolt mains. There are also 400 blocks that have 2 bolt mains that have a different casting #. The 2 bolt mains are just as good. Hope this helps.
    lemondana and Deuces like this.
  8. nutnfits
    nutnfits
    The casting #s for the 2 bolt mains would end with either , 509 or 817 .
  9. squirrel
    uh...are you trying to identify an engine? or help with someone else's ID?
    If you want help to ID an engine, post the numbers here and we can help. If not, this is a very strange thread....
    Deuces and lemondana like this.
  10. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yeah, they really did put casting numbers and stamping codes on them for a reason.
  11. lemondana
    lemondana
    from Lincoln NE
    I have access to a cheap engine, It has a different casting number-I don't have it with me and this friend said by the stamped number that it was a 400. The numbers I looked up said 350 or 68 327, or a 302. He said he knew what he was talking about. The casting number ended in 010. Thanks for the replies.
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    010 is definitely NOT a 400.
    swade41, Deuces, lemondana and 4 others like this.
  13. LOU WELLS
    LOU WELLS
    from IDAHO
  14. squirrel
    yup, the 010 block was almost always a 350. It has the wrong size bore and main journals to be a 400.
  15. DDDenny
    I can't believe the harmonic "balancer/damper" crowd hasn't muddied up the conversation yet, and the "freeze plug/core plug" guys must be taking a much needed nap.
