Chevy 6 Hesitation
Discussion in 'The Hokey Ass Message Board' started by jquesal, Feb 15, 2009.
  1. jquesal
    jquesal
    Hi, I've got a '49 Chevy w/216, manual choke, 3 speed stick and 6 volt system. Problem is a bog or hesitation coming off idle. Also get an occasional pop back through the carb. Carb is new pro rebuild (Carter W1) and seems to react well to minor adjustments. If running above idle it accelerates smoothly(but still get some occasional minor popping back through carb). Timing is good, valves have been set, etc. Any help is appreciated.:confused:
  2. Allmotor
    Allmotor
    Check your va***n advance.
  3. bigdog
    bigdog
    accelerator pump?
  4. flathead4d
    flathead4d
    Definitely check the vacuum advance for a leak or bad diaphram. Also check the wire that runs under the distributor plate. It might be shorting out when the plate rotates.
  5. Ice man
    Ice man
    definatly look at the accelerator pump.
  6. 29nash
    29nash
    from colorado
    Is the heat-riser stuck in closed position? That would make it feel 'cold blooded' until the entire block/manifolds heated up. QUICK way to check that is to apply about 1/4 travel of choke and see if the accell/backfire stops.
