Chevy AD C-Notch
Discussion in 'The Hokey Ass Message Board' started by Wicked50, Aug 10, 2010.
  1. Wicked50
    Wicked50
    Do they make a c-notch's specific for 47-54 Chevy trucks?
  2. gimpyshotrods
    gimpyshotrods
  3. R. Seghi
    R. Seghi
    Wouldn't Gambino have this too? And he's a little more friendly. Alex is a very cool cat.
  4. Wicked50
    Wicked50
    I don't think 3" is enough to lay running boards is it?
  5. Wicked50
    Wicked50
  6. Wicked50
    Wicked50
    57 3100
  8. Wicked50
    Wicked50
    I did some measuring and bottom of frame to top of axle is 2 inches less than the running boards to the ground so a 3 inch notch should hopefully be enough
  9. gimpyshotrods
    gimpyshotrods
    Depending on your tire size it may not be. For more drop than 3", you will need a step or bridge notch. A simple notch will not be enough. None specific for an AD truck that I know of. They don't need to be. Once you have gone that far, a universal one will do, or make your own.
  10. I Did a 8" step to lay running boards on a 5.60-15 tire..
  11. Wicked50
    Wicked50
    Do you have any pics of the bed area with the notch
  12. Leevon
    Leevon
    from Nixa, MO
    Hate to poo-poo on any vendors but the CPP AD truck notch is total sh**. I ordered one and it didn't fit either 47-53 or 54-55 frames at all. I don't mean a bend here, bend there I mean flat out wrong. Called, e-mailed, sent pics, and never got a resolution until I posted it in another forum. I should have known when the advertised p/n, my order p/n and the p/n on the website were all different.
    wound up just making one which I should have done in the first place. Oh yeah, with 28" tires the 3" notch puts my running boards about 3" off the ground.
  13. gimpyshotrods
    gimpyshotrods
    Ok, forget I mentioned it.
    Step notch from Gambino, then. You can talk directly to Alex if you need any help, too. He's a real stand-up guy.
  14. rustypipes
    rustypipes
    from san jose
    Any step notch will work, All need to be trimmed to fit
  15. Wicked50
    Wicked50
