Technical Chevy blueflame balancer key-What are the chances?
Discussion in 'The Hokey Ass Message Board' started by 36roadster, Apr 18, 2023.
  1. I was going to install a harmonic balancer onto a Blueflame crank, so I went to put the key in the slot on the crank (slot at 12 O'clock), just put it slightly in the slot, and dang! It fell out - or so I thought. After about a half hour with an inspection mirror, a magnetic pick-up do-hickey, flashlight and lots of new cuss words, there was no sign of it. The only other place it could have gone- gulp- was past the seal and into the timing cover. I have looked in there as far as I can see, but you can only see straight in and past the seal. I have turned the motor over by hand, and it goes around 360 degrees. I thought I would quickly remove the timing cover and have a look, but no, the clever engineers at Chevy managed to put 2 bolts at the bottom which have to be accessed after removing the sump, so I would have to order gaskets, etc, which are not common here. Anyone lost a key past the seal into the abyss of the timing cover? It seems you would really have to push it past the seal (I can't try that as I don't have another key).Or would I have more chance at winning the lottery?
    41 GMC K-18 likes this.
  2. Budget36
    Budget36
    Maybe you can take a magnet on the outside of cover bottom and “work” it up. Can you get a new seal easy enough? If not you’ll have to see if you can get the key high enough. Maybe grind down some needle nose pliers and maybe if you say a few Hail Marys you can snag onto it.
  3. 5window
    5window
    Sorry for your sticky situation. The odds of that happening are nearly 100% so, hopefully, someone will have a good answer.
  4. squirrel
    can you get another key, and leave the missing one wherever it is? I can't see it causing any problems.
    Beanscoot and Truckdoctor Andy like this.
  5. and glue a magnet on the outside of the bottom of your pan so that the key winds up there :D
    5window likes this.
  6. My understanding is that some things in Australia work in reverse of the "normal" world ... toilet water swirling for example. Any chance your gravity made it "fall" to the ceiling? o_O
    modagger, mustangsix, SS327 and 2 others like this.
  7. In all honesty, if it doesn't look like it could squeeze past the seal without a shove, keep looking elsewhere. Take a break and start the search again with a clear mind.
    The Shift Wizard and squirrel like this.
  8. ClayMart
    ClayMart
    Is there enough room to maybe sneak a bore-scope into the timing cover?
  9. BJR
    BJR
    Can you pull the fuel pump and look into the pan from there? Or fish around with a magnet or bore scope.
  10. Doublepumper
    Doublepumper
    from WA-OR, USA
    Is it possible the key is slightly magnetized and is stuck somewhere? Hope you find it with no major issues.
    SR100 likes this.
  11. What about a bore scope thru the oil pan drain?
    5window likes this.
  12. jimmy six
    jimmy six
    You found the reason many Chevrolet/GMC 6 guys tap the 2holes in the front main 3/8-16 and install header bolts in the bottom of the timing gear cover.
    I’m guessing it will never go into the pan. There are 2 oil drain holes I believe and the woodruff is too wide for them I think or it would need to be inline with the hole to fit. I believe it’s in the timing cover and you don’t want it in there. If you can turn the engine over you are lucky as there is very little clearance between the crank gear and the cover.
    If the engine will turn over I would attach a magnet to the right side of the cover off center and slightly on the flat area.
    Good luck.
  13. BJR
    BJR
    I would go over the shop floor with a magnet, and then an empty shop vac. Then you will be sure it's still in the engine if it doesn't show up in the vac or magnet.
    AVater and gary macdonald like this.
  14. I will have another look today, after I let all the steam out of my head yesterday. I will remove the grille so I can see in there better . There is not enough room to get a borescope past the seal, and I don't think it would have worked it's way from the timing case into the sump. The magnet idea might be the go, and cross my fingers.
  15. seb fontana
    seb fontana
    from ct
    Probably in your pants cuff...
    vtx1800, SDhotrod, Budget36 and 2 others like this.
  16. 52HardTop
    52HardTop
    If my memory is correct, the 51 has a front engine mount just under the timing cover? I bet the key fell in that area and you haven't found it yet maybe because you didn't think to look there? I would take a look. I can't believe it would slip into the timing cover. The groove for the key can't be that long to allow the key to fall into the cover.
    Cosmo49 and alanp561 like this.
  17. tb33anda3rd
    tb33anda3rd
    I went nuts one time looking for a small bracket. I hadn't moved out of the area, it just dissappeared. turned out it stuck to the magnet on the drop light which was in my hand the whole time I was looking:eek:
    38Chevy454, twenty8, Budget36 and 4 others like this.
  18. s55mercury66
    s55mercury66
    from SW Wyoming
    I lost a C-clip one day. I searched and dug and went all over the area with a magnet, no luck. A week later it fell out of my bootlaces.
    seb fontana, alanp561 and 41 GMC K-18 like this.
  19. I used a wee borescope (like a harbour freight one), and I found the little *******- down the bottom inside the timing cover. I am going to epoxy a small magnet to some wire and go fishing!
  20. flatheadpete
    flatheadpete
    from Burton, MI
    Glad you found it! Now let's hope extraction goes smoothly.
  21. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    A rare earth magnet is very powerful. One the size of a pencil eraser will certainly do the job
  22. squirrel
    A powerful magnet will stick to everything and never make it to where it needs to go....btdt.
    Happy fishing
  23. 5window
    5window
    If it's out of the way, might it not stay there?
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    tommyd and AVater like this.
  25. alanp561
    alanp561
    Can you just stick a larger rare earth magnet on the outside of the cover right where the key is? They should both stay in place.
    seb fontana likes this.
  26. Budget36
    Budget36
    I find magnets very attractive.
    Bob Lowry, BJR and The Shift Wizard like this.
  27. spanners
    spanners
    Except their two like poles won't attract you.
  28. Doublepumper
    Doublepumper
    from WA-OR, USA
    You need a good magnet to drag it up from the outside. This thing has saved my *** a time or two. mondomag.jpg
    Good luck!
    41 GMC K-18 and alanp561 like this.
  29. bangngears
    bangngears
    from ofallon mo
    Ever time i drop something it hits my shoe and is never to be seen again, magnets, flashlights, glue on a stick, vacuums, brooms, wet shop towels, mirrors, and air chucks do not help.
    alanp561 likes this.
  30. Shove a magnet into a metal hole, talk about frustration. Someone should make a small powerful electromagnet.
    Last weekend I had a 5/16 magnetic nut driver that somehow left the magnet stuck to the screw. There was no way that magnet was going back in there.
