Chevy brakes
Discussion in 'The Hokey Ass Message Board' started by cubic_inch, Feb 15, 2012.
  1. cubic_inch
    cubic_inch
    I have a 1929 chevy with the original brakes in the front end and now I'd like to swap brakes. I would like to keep the original spindles and steeringassembly, so what kits can I buy and from where?
  2. Don't know about kits, but you can use early 50's Chevrolet truck axle/spindles.
  3. squirrel
    Instead of thinking "kit", think "junkyard"....or what we used to be able to get at the junkyard.
    A 40s truck axle with 50s truck brakes would be good.
  4. 1928chevycoupe
    1928chevycoupe
    I have a 1928 chevy and the same question.
    1) why exactly do I have to switch to the 1940 axle?, I cant use the 1928 axle?
    ( I will probably want to drop my stock axle in the future, but if I need to be using a newer axle to use newer brakes, clearly there is no point in having it dropped )
    Thanks!
  5. MATACONCEPTS
    MATACONCEPTS
    Do the switching at the 4 u-bolts axle/springs
  6. squirrel
    The early spindles and backing plate mounting bolts are kind of small compared to the later stuff, it makes it easier to just swap the whole assembly. but you could try to just swap the brakes if you want to, it should be doable.
  7. Ghost28
    Ghost28
    There is a guy on here, I believe his name is believe it not (28 chevy). He switched out the front on his 28 chevy to disc brakes using the original axle.
  8. The Filling Station has the brackets to convert the original spindles to disc brakes. www.fillingstation.com part number FS-715. Junk yard would probably be cheaper though.
  9. 1928chevycoupe
    1928chevycoupe
    I appreciate all these comments guys, thanks!
