Technical Chevy Clutch Fork
Discussion in 'The Hokey Ass Message Board' started by blowby, Jun 21, 2021.
  1. blowby
    blowby
    from Nicasio Ca
    Mine has spring tangs where the TO bearing slides in. I couldn't get them inside the slot where it seems they should go, so I put them behind the back flange and put in the trans, thinking they would pop themselves over the flange when I pushed in the clutch. Doesn't seem to be happening. They do go in the slot, right?
    Long time since I've done a Chevy clutch, don't remember having those tangs.
    Lloyd's paint & glass likes this.
  2. TCATTC
    TCATTC
    Right, they are there to keep the bearing from rattling.
  3. blowby
    blowby
    from Nicasio Ca
    ****. Thanks.
  4. DDDenny
  5. blowby
    blowby
    from Nicasio Ca
    Thanks again, I've now gone from incorrect to correct. Wasn't too bad, I had only put the front 4 ****** bolts in. But I think I'll skip the gym tonight..
  6. Corn Fed
    Corn Fed
    Do you have an OEM fork or a reproduction? The last car I did I had a repro fork that just didn't fit right with the TO bearing. It was a tad tight and ended up breaking the back flange/lip off the bearing. I threw the arm (and broken bearing) away and got an OEM one that fit like a glove.
