Chevy Crank Damper for Flathead
Discussion in 'The Hokey Ass Message Board' started by trades707, Jan 19, 2014.
  1. trades707
    trades707
    from Oregon
    Does anybody supply already machined 327 Chevy crankshaft dampers replace stock 59-AB Ford Flathead crank end assembly? Or do I just need to find a damper and look for a machine shop? I'd like the expensive rebuild to last a few years with occasional high rev runs.
    Thanks
    Abe
  2. Jimmy2car
    Jimmy2car
    from No. Cal
    For a 59 type engine some things need to be considered:
    What vehicle?
    Is there room for one?
    What pulley setup are you planning on using?
    Yes, you will probably have to have one of your liking machined to fit.
    It's a great idea, but may be difficult to accomplish.
    I know they are made for the 8BA type engines (narrow belt setup)
    Is one necessary? IDK
  3. christmas tree
    christmas tree
    I have a Fluid Dampner on an 8ba with the narrow belt. Reworked some pullys for the water pumps and run 1 belt with a GM alt.
  4. I did this on mine with a Powerbond balancer...cheap, effective and looks factory.
    From memory the SBC balancer needed honing for a tight fit to the FH crank
  5. What is the reason for the damper? can someone show pics,I've got a
    8cm merc engine 1951,thanx Webb.
