chevy engine id?
Discussion in 'The Hokey Ass Message Board' started by kenbob26, Sep 27, 2010.
  1. kenbob26
    kenbob26
    traded for a rat rod this last weekend and the engine code is 10086036 0r 10066036. what is this block ? i looked and the books i have dont list this number?
  2. Snarl
    Snarl
    First off, "code" would be a stamped series of numbers/letters, not a casting number...
    V8 - casting number at the back of the block is not the engine code. The engine code is stamped on the small machined pad in front of the p***enger side cylinder head.
  3. 55 dude
    55 dude
    google is your friend!
  4. squirrel
    does it say HECHO EN MEXICO also?
  5. raidmagic
    raidmagic
    Sorry I can't find anything that starts 100****
  6. Novadude55
    Novadude55
    from CA
    Just a couple of google searches resulted in this info,,
    Here are two examples, what the block casting numbers(rear drivers trans mount flange) and the engine code pad(front p***enger block surface) look like,
    Report back with pics or what you see on yours, we can figure it quick then,,,,
    http://www.chevellestuff.com/qd/block_casting_by_year.htm
  7. Truckedup
    Truckedup
    Yup,Hecho in Mexijo.....10066036 or 10066038 is a 350 Goodwrench crate engine.Some are 2 bolt ,some are 4 bolt mains.
  8. 56sedandelivery
    56sedandelivery
    It's a 10066036 casting number, Target Master 350. Hecho en Mexico (made in Mexico). Some say lousy machine work, some swear by them. Personally, from my experience with one, I say the cast iron is "softer", as the one I had wore the bores quickly. It dropped #8 exhaust valve right after warranty. I'm going to be using the block to make a large journal 327. Butch/56sedandelivery.
  9. kenbob26
    kenbob26
    This what I thought when I first saw the long code. Well the guy either new what the engine was or not. We all know its not a 327 like he claimed. Engine seams strong good oil pressure. I may just leave it in the Truck for now. Thanks to all who responded. I do have a large journal 327 ? Hmm.
