Technical chevy engine mount torque spec
Discussion in 'Traditional Customs' started by 1959Buick, Oct 18, 2018.
  1. 1959Buick
    1959Buick
    from BC Canada
    Does anybody has the Small Block Chevy torque Engine Specifications for the
    motor mounts to engine
    motor mounts to frame
    motor mounts to motor mounts
    One a 283 and 350 engine
    Thanks your help.
    The internet gives me numbers from 35 - 60 pounds
  2. squirrel
    usually 3/8" bolts (such as hold the mount or bracke to the block or frame) get 30-35 lb ft
    7/16" as used for motor mount bracket to mount, would be more. But, there are several different styles, and we'd need to know what you have to give you the correct answer.
    I don't think I've ever used a torque wrench on either, I just get them tight.
  3. DDDenny
    Jims right.
    That's why GM used lock washers on most everything.
    mad mikey likes this.
  4. 3/8" hardware = 1 grunt, 7/16" hardware = 2 grunts. 1/2" hardware = 2 grunts and a cuss word.
  5. belair
    belair
    Tighten em up till they squeak.
  6. 2935ford
    2935ford
    Squeak not snap! :)
  7. jimmy six
    jimmy six
    Print a torque chart off the internet for different sizes, grades, threads, and alloys of cap screws. Put in your tool box lid or post it in garage on a cabinate door.
    jazz1 and mad mikey like this.
  8. Tighten until the threads strip, then back off 1/4 turn.
  9. tight but not broke,
  10. 1959Buick
    1959Buick
    from BC Canada
    Thanks everybody
  11. 41rodderz
    41rodderz
    from Oregon
    :D Spot on.
  12. 03GMCSonoma
    03GMCSonoma
    Tighten them until you asshole puckers up like it had a drawstring on it.
    bobss396 likes this.
  13. Peashooter67
    Peashooter67
    Before or after the 12 pack?
  14. We had a critical piece of hardware at work that had to be very tight. We made up some sample pieces in the shop... real parts were too valuable to play with, installed the bolt and crept up on the torque until the bolt broke. Did 3 of them actually, one with never seize on it. Finally we broke it in all 3 and determined the average force was close enough to help us. From there, we backed off the torque value by 15% and have been using that since.
    My general torque formula is:
    T = Ar x k x Ftu (at a %) x Nominal Thread Diameter. Everything is in inches, answer will be in inch-lbs.
    Ar: is thread root area
    k: is coefficient of friction, .20 for dry thread, down to .14-.18 for a lubricated thread
    Ftu: is Ultimate tensile strength for the bolt material
    %: I generally use is 65%, 50% I use for more of a safety factor (not breaking a very hard bolt)
    Nominal Thread Diameter: is what ever the bolt is, 1/4" = .25
    I apply a plus or minus 5% to what I get.
    This is a great source for a torque calculator. I often bounce it off my formula as a check.
    http://www.futek.com/boltcalc.aspx
    pitman, jazz1 and squirrel like this.
  15. as a general rule... if there is not a printed torque value in a service manual I tighten it until I think it is tight enough and then check it again after a few drives and heat cycles (50-100 miles)
    sometimes I will use the 1 finger wrench pull, 2 finger wrench pull, 3 finger wrench pull, etc, method of torqueing fasteners... hook a finger or two over the handle of the tool and pull until your finger is ready to slip off... the more fingers you use, the more torque applied...lol
    Chappy
    scotty t likes this.
  16. squirrel
    another "rule of thumb" for torque, is to use a ratchet and socket with a drive size roughly the same size as the bolt. So use a 1/4" drive ratchet on 1/4" bolts, 3/8" on 3/8" bolts, and 1/2" drive on 1/2" bolts, and pull kind of hard on the handle of the ratchet to get the bolt tight.
    (don't do this with long handled ratchets, of course)
    scotty t and pitman like this.
  17. pitman
    pitman
    Fortunately most engine block threads use coarse bolts. Fine thread is tougher to estimate when you're tight/torqued.
  18. Terrible80
    Terrible80
    Never torqued a motor mount in my life. Am I missing something?
    scotty t and sunbeam like this.
  19. sunbeam
    sunbeam
    My question why in the 60s did Chevy put the long mount to frame bolt in from factory so you had to pull the fuel pump to get to it out?
  20. SEEKONK JIM
    SEEKONK JIM
    use a box wrench..when you fart it is done ..if you shit your pants thats to much...
    millersgarage and 03GMCSonoma like this.
  21. DDDenny
    What do you guys have against split lockwashers???
    Edit
    I recieved a PM from a HAMB friend that thought I was out of line with my original post, not saying he is right or wrong so just thought an edit was in order.
  22. 29moonshine
    29moonshine
    I was told if you use a split washer tighten it until the washer flatten out then 1/2 turn
