chevy head question
Discussion in 'The Hokey Ass Message Board' started by gassersteve, Aug 6, 2012.
  1. What are the difference to staggered valve cover bolt holes and the non staggered bolt holes other than the obvious staggered and non staggered valve cover bolt holes?
    Are the non staggered holes earlier heads?
  2. squirrel
    Staggered holes (top two holes are closer together than bottom two holes) were used from 1955 to mid 1959 production, then they were all "straight" holes.
    so only early heads have staggered holes
  3. hotrod40coupe
    hotrod40coupe
    There are many differences in the staggered hole versions by themselves without comparing them the the "straight" holes.
  4. I got a 283 long block in a trade and never noticed the holes for the valve covers until yesterday when i bought some staggered hole cal custom finned valve covers. Now the search is on for staggered heads
  5. Mr48chev
    Look for a set of power packs with the little triangle on top of the rectangle on the end. That is the minimum you want for a good little street engine.
    [​IMG] They came on four barrel equipped cars.
  6. squirrel
    Hey, I have some of those.....
    although the last pair I sold went for about five bills
  7. I have heard people saying power pack. Never knew the distinction. I will keep my eyes open more, and my wallet open. Thanks guys
  8. Are 333882 heads worth getting for $50? I am building a 283 and found them on cl
  9. squirrel
    they're not what I would use on a 283
  10. barslazyr
    barslazyr
    What is the difference between the powerpack and the double hump heads?
  11. squirrel
    They're both the small chamber design, but the powerpack has smaller ports and valves than the double hump. Powerpack is the high perf head for a 283, double hump is for a 327.
    although you can put any head on any engine, mostly
  12. jr9162
    jr9162
    Don't put heads with 2.02" valves on a 283, the bore is not large enough...
  13. squirrel
    That might be true, fortunately there are very few original Chevy heads that came with 2.02 valves
  14. barslazyr
    barslazyr
  15. Thanks Jim. I will hang onto my 50 bucks for some 997's if i can ever find a set
