Chevy hydraulic clutch conversion
Discussion in 'The Hokey Ass Message Board' started by Bad 35, Jan 22, 2007.
  1. Bad 35
    Bad 35
    what s a good setup to use ? I have a '63 SBC in a '35 Ford and I cant get manual linkage to work out. Does a newer GM hyd. throw out work with a muncie and old bellhousing? Thanks for any help Gregg
  2. I used a bell housing from a Chevy dump truck that had a 350 in it.External slave with a firewall mounted master.The only drawback is the hole where the trans fits...its larger thus no support at the front bearing retainer. Works so far.
  3. fab32
    fab32
    Ratmotor, Not a problem. Just have a machine shop turn a ring with the OD the size of the bellhousing dia. and the ID the size of the bearing retainer. Might have the OD turned .0005"-.001" oversize . that way once its assembled the slight press fit will hold the ring snug in the bellhousing and allow the trans to be removed leaving the ring in place.
    Frank
