Technical Chevy in a 40 Ford
Discussion in 'The Hokey Ass Message Board' started by RAF, Apr 4, 2025.
  1. RAF
    RAF
    from MA.
    The flathead in my 40 coupe is shot and I have a good Chevy283 and adapter for it. Does anyone know where I can get a flywheel, clutch disc and pressure plate for this conversion? Any help is appreciated. Really can't afford to have the flathead rebuilt.
  2. lilCowboy
    lilCowboy
    The pressure plate is the impossibly hard to find part
  3. hotrodA
    hotrodA
    lothiandon1940 likes this.
  4. chevyfordman
    chevyfordman
    I did a Ft Wayne pressure plate but I haven't had a chance to try it out yet. IMG_2584.jpeg
  5. 1946caddy
    1946caddy
    from washington
    First find a flywheel that will accept a 10" clutch- pressure plate. You may have to take your flywheel to a machine shop and have them drill the flywheel to accept the pressure plate. You will need a flywheel for a two piece rear main. Depending on the block, you will probably need a starter that bolts to the adapter and matches tooth count on flywheel. Speedway also sells a bushing for the crankshaft. This kit from Speedway should work.
    Flathead 10 Inch Clutch Disc/Pressure Plate/Release Bearing Kit
  6. HOTRODPRIMER
    HOTRODPRIMER
    Speedway motors has what you need but pricey. HRP
  7. theHIGHLANDER
    theHIGHLANDER
    Ft Wayne clutch is good but holy ******** they're proud of their stuff. Try here...
    https://kyclutch.com/
    There used to be pics of their place somewhere in 'net land, and just 1 look said these are the guys. Good luck. VERY reasonable and friendly to deal with.
    Quick edit, found a pic. Was I lying...;)
  8. 1946caddy
    1946caddy
    from washington
    Tow Truck Tom likes this.
  9. My flywheel is from a mid 60s c10
    I can post a casting number later if you need it. Has the correct blott pattern for the Borg and Beck pressure plate
    using my merc pressure plate.
  10. theHIGHLANDER
    theHIGHLANDER
    Ok, I found my flywheel that's supposed to take the flatty pressure plates. Is this it? 20250405_151539.jpg
    anthony myrick likes this.
  11. 1946caddy
    1946caddy
    from washington
    This fits lots of different Chevrolet p***enger cars, trucks from 1957 1958 1959 1960 1961 1962 1963 1964 1965 that use the large outside diameter flywheel but the small 10.4" clutch flywheel with 168 teeth.
  12. Rob28
    Rob28
    from Calgary AB
    I went with Fort Wayne as well. Not cheap but so far everything has lined up correctly. I went with a Summit racing 168 tooth flywheel as well that had the dual clutch bolt pattern
  13. RAF
    RAF
    from MA.
  14. bangngears
    bangngears
    from ofallon mo
    Chevy pressure plate, ford disc and pilot bearing from Speedway
  15. RAF
    RAF
    from MA.
    Was told I need 50 mercury pressure plate.
    Automotive Stud and Tim like this.
  16. 40Standard
    40Standard
    from Indy
    just drop in a chevy ****** with the 283
    alphabet soup and NoSurf like this.
  17. hotrodA
    hotrodA
    The Ft Wayne supplied Mercury Borg and Beck pressure plate part number is 1310.
    Guess you chose not to read my previous post. The referenced thread should answer these questions.
  18. Pulled these out of 51 mercs
    1319 and 988
    Both bolt to the gm flywheel #3703870
    Is there any difference with the 1310 pp?
    Dont know
  19. hotrodA
    hotrodA
    ^^^^^ Good point! Don’t know either unless it’s spring rates.
  20. bangngears
    bangngears
    from ofallon mo
    HotrodA, no, chevy pressure plate to a chevy flywheel and a Ford clutch disc. Then call Speedway for the correct pilot bearing. iv have done this several times.
    jimmy six and 1946caddy like this.
  21. RAF
    RAF
    from MA.
  22. RAF
    RAF
    from MA.
  23. Watcha still need to know?
  24. RAF
    RAF
    from MA.
