chevy inline fuel pump....
Discussion in 'The Hokey Ass Message Board' started by cwatson1953, Mar 4, 2008.
  1. cwatson1953
    cwatson1953
    real quick,....will a fuel pump(w/ vacuum wipers) from a smaller 6 (235) fit a larger 6, 250/292?
    i'm gonna have to run vacuum wipres 'till $$$$ allows for an electric motor. problem is, with my carb and intake set up, i no longer have vacuum for the wipers. so i was thinking about just doing the old fuel pump w/ vacuum....but need to make sure it will fit.
    OR/AND if anyone has any part numbers for one that would fit a '75/'76 Chevy 292L6, that would be sweet!:D
    thanks.
    Chris
  2. cwatson1953
    cwatson1953
    i THINK the bolt pattern is the same....but just wanted to check and see if anyone knows for sure....
  3. Hellfish
    Hellfish
    the bolt pattern may be the same, but is the actuating arm the same length?
  4. Hellfish
    Hellfish
    all the 235s I've run got vacuum to the wipers from the intake manifold
  5. cwatson1953
    cwatson1953
    yea, thats what i've gathered on alot of them. my original 235 had the fuel pump w/ vacuum on it. but that engine is long gone now.
    i just added Langdon's headers and intake and a carter afb.
    the intake has 2 ports, one is my brake booster, the other is for my modulator on the TH350.
    the carter only has one vacuum port, which is for the distributor advance. the rest of the carb is all mechanical.
    i had one person suggest "tee-ing" into my brake booster line since wipers are not some you run ALL the time....but i'm afraid that could pull too much vacuum away from the booster. i'd rather have brakes than wipers:eek:.
    as i said before, i have no objection to the electric wiper motor, 'cept the money right now. so i'm looking for a temp solution.
    thanks for the input.
  6. cwatson1953
    cwatson1953
    thats what i don't know....
  7. Stovebolt
    Stovebolt
    Be on the lookout for a 57 Chev electric wiper motor, as thy bolt in, and even the original cable will operate it.
    thats what I did on my 54, all I needed to do was to take some power off somewhere else to run it - so long ago I can't remember where I took it from.
  8. cwatson1953
    cwatson1953
    sweet! sounds even better. and hopefully cheaper than the 200$ motor NCA sells...
    THANKS!
  9. Twisted6
    Twisted6
    why not tap another hole in the intake for your wipes??
  10. cwatson1953
    cwatson1953
    cause i'm lazy and worried about f-in up my new intake. hehe. :eek:
  11. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    If it was me I'd tee into the line going to the power brakes. No matter where you hook it up it will be taking some vacuum away from the brake booster. The reason the brake booster is so big is so there will be a vacuum reserve there for times of low vacuum. Thats also why there is a check valve where the hose hooks up tho the booster.
  12. Road Runner
    Road Runner
    The early 235 and later 250 chevy 6 fuel pumps do not interchange.
    Even a****st 235 pumps you have to get the right year for the block.
    Actuator levers came in several versions. Some don't fit at all, others may fit but will eventually break, if they don't match the same year block.
    The fuel pumps with air ***ist pump on the bottom still need to be connected in series with the intake vacuum.
  13. cwatson1953
    cwatson1953
    well, that answers that. thanks so much.
    i'm gonna try and look for a '57 electric motor.
  14. cwatson1953
    cwatson1953
    thats a very good point! thanks!
  15. nexxussian
    nexxussian
    Are you talking about getting this motor?
  16. cwatson1953
    cwatson1953
    not quite. thats the "repop"....a bit pricey for me. i've found some original/rebuilt 1957 chevy electric motors on ebay that are more affordable.
  17. nexxussian
    nexxussian
    I was wondering as it is similar (if not the same as) the one for the '50 GMC 100 that I have to work on next. Do the OE motors have 2 speeds? I know the Newport motor is not cheap, but with 2 speeds, variable intermittent (and self park, but I expect the OE one does that too) I really want that one.
    If I can afford it or not, that's another matter entirely.:rolleyes:
  18. cwatson1953
    cwatson1953
    as far as full functions of the '57 motor, i am not sure. i know its a 2 speed....but thats as much as i know. sorry.
  19. gas pumper
    gas pumper
    I'd tee into the Vac line to the trans modulator. Just cause it would be an easier fitting to do, than a tee in the bosster line. Va***m wise either would be fine.
    I use rainex on my 54, have for 15 years. looks a lot better with two chrome bullets than wiper blades. And Iv'e been out in RAIN.
    Frank
  20. 325w
    325w
    The tri five wipers are two speed. Good ones around here are a much as the newport. The tri fives are perfect replacement for the vac. I'd save the bucks and do like the other guys says run the vac to the smallest hose and use rainex. I do that on the 36 and no problems. how often do you get caught in the rain ?
  21. heavy
    heavy
    Yea that's what I was thinking. I drove 250 miles to the roundup last year in pouring rain w/ rainex worked for me so....
  22. nexxussian
    nexxussian
    I figured, I just wasn't sure, thanks.
    Thanks.
    As for how often I drive in the rain? So far every trip over 15 miles in my A.
