chevy inliner guys (250)
Discussion in 'The Hokey Ass Message Board' started by JohnnyP., Jul 13, 2010.
  1. JohnnyP.
    JohnnyP.
    im in the process of looking for a 250 straight six right now, and im not sure if the trans bolt patterns are the same for the sixes as the V8s. i have a great deal on a 3 speed with everything ( w bell housing) and its all in really good shape. will this bolt up to a 250 or do i need to look for a bell housing too?
  2. riv63
    riv63
    from Texas
    From about 1955 up, you should be OK.
  3. JohnnyP.
    JohnnyP.
    thats awesome. im looking to put it in my new 54 chevy bel air. did they change the location of the sump on the oil pans or should i be ok with the stock front steering/ suspension. like i said i dont have the original or old engine here so im trying to not buy things twice.
  4. draggin'GTO
    draggin'GTO
    All of the 'modern' Chevy sixes ('62 and later 194, 230, 250 & 292) share the same bellhousing bolt pattern as the 1955 and later Chevy small-block and big-block V8s.
    You're in luck.
    There are a variety of oil pans that are rear-sump for the Chevy six. The deep rear sump 292 truck pan may be what you need but the current 250 pan, if it's a rear sump, may work.
  5. You will be fine with the combo you are doing.
  6. inline 292
    inline 292
    The 230,250,292 family that started in 1963 share the same rear block/crank layout as the '55 & later V-8 Chevy motors. The 235, 261 6 cyl. motors that were used before the 230 family came out have a different pattern & require their own bellhousing.
  7. 51hrdtp
    51hrdtp
    Great motor trans combo. Yes they bolt up. keep the rear gear at 3.05 - 3.50 range to get the most out of it. Had a friend with this combo and he would go up some heavy grades while towing a trailer at 60 with no problems.
  8. JohnnyP.
    JohnnyP.
    im just looking for something that will get me around with good gas mileage. the 3 speed is out of a 57 chevy car so im super stoked its not a truck trans. anything i need to watch out for when looking for an inline? are there any parts on these that are interchangeable with the V8s?
  9. Non Syncro 3spd with linkage prone to lock up?
  10. JohnnyP.
    JohnnyP.
    the 57 trans? thats a good heads up.
  11. JohnnyP.
    JohnnyP.
    is this a bad trans to go with? hould i pick something a little newer?
  12. uglydog56
    uglydog56
    Go to www.inliners.org and all your questions will be answered, including several you haven't thought of yet but are going to be asking soon. That's where I went, and have learned tons.
  13. bob308
    bob308
    if the trans is free it is ok for a while.you have to come to a dead stop to put it in 1st. gear every time. if your linkage is not adjusted just right you will wearout the 2-3 shift fork. then it will stick in second and that is a long drive home.
  14. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If I were going to the bother of a driveline swap, I'd at least find a '66 or newer Saginaw 3 speed. Much tougher, syncro low gear, and dirt cheap.
  15. inline 292
    inline 292
    Good info given in the posts above. You can tell the '66 & later type by their 7 bolt sidecover vs. the older, 4 bolt ones.
  16. mart3406
    mart3406
    from Canada
    I'd avoid using the '57 three-speed ******. Besides
    having no synchro on 1st gear , they're pretty weak
    too. I remember 'back in the day', circa early-70's a
    buddy and myself, blowing one up about once every
    other week in his 283-powered '61 Chevy. Back then
    it was no big deal - just go back to the boneyard and
    pick up another one for 25 bucks and slap it in! We got
    to be pretty quick at changing ******s - once, even
    doing one right on the side of the road! :eek:
    Any of the later - and much stronger - GM 'full-synchro'
    style 3 speeds, or a Saginaw, Muncie or GM-pattern T-10
    4-speed will also bolt right up and would be a nice combo
    with the 250 6-banger. If you want to go newer still and
    get 5 gears - with O/D on 5th as well - a T5 five speed
    from an 80's or '90's vintage S10 or Camaro will work too.
    That'd be my choice. If you go with a T5, just avoid
    the weaker and 'lower 1st geared and shorter O/D' ratio
    '4-banger-style' T5 and instead, get one that originally
    came with a V6 or V8.
    Mart3406
  17. You haven't lived until you learn how to quickly unstick the linkage QUICKLEY at a red light!
  18. JohnnyP.
    JohnnyP.
    haha. i like this thread now. a lot of information. im not trying to build anything that im going to be racing anyone in. i just want to cruise with me son and get to work. and i used to have a T5 ( could probably get it back) but i would much rather go with a side loader 3 speed. you can fit more people in it with out the awkward "shifts". thanks everyone for input. lets keep this going for others.
    also, if i got a 3 sped out of a truck, what rearend gears would i need to make the ratio decent for a cruiser?
  19. A truck trans has a 1 two 1 gear ratio in third just the same as a car. Not a nickles difference between a car and truck three speed. OldWolf
  20. chevyfordman
    chevyfordman
    Install a hei dist, as it will give you tons of cruising power, worth every penny, if you want to ever want to install A/C, I have all the stuff you need.
  21. mart3406
    mart3406
    from Canada
    All of the p***enger car and light truck' 3-speeds
    - and 4 speeds too for that matter - are '1 to 1'
    - ie - 'direct' - in high gear, so the ****** you use
    won't have an effect on what rear gear you want
    for "cruising". The only difference between the
    various 3 and 4-speed transmissions other than
    ultimate torque capacity is the ratios in 1st and
    2nd gear (and 3rd gear in 4-speeds) and the
    spread between them> Additionally, most all of
    the car and "light truck" trannies are pretty similar
    in having 1st gear ratios in the 2.40 to 2.80
    to 1 reduction range, Note - since you asked
    specifically about 'truck transmissions ; when I
    use the term "light truck' I'm referring to the
    3-speeds used in 1/2 ton trucks. I'm not referring
    to the 'granny-gear low' top shifted 4-speeds used
    in some 3/4 and most 1-ton and up trucks! :eek:
    About the rear gears - considering the size weight
    and "just cruising" use for your car - and the power
    output and torque curve of a stock or near stock
    250 inch Chevy 6-banger, - you'd do good to look
    for rear gears in 3.50 to 1 range. I wouldn't stray
    too far from this in either direction - maybe
    something around 3.70's at the lowest and 3.36s
    at the high end. - and 3.70's to 4.11 in the unlikely
    event you come across a '3 speed with overdrive'
    The good news is that these rrear gear ratios were
    the ones that GM most commonly used in 6-cylinder
    powered cars in the the '50's and 60's, so finding a
    gear set or a complete rearend shouldn't be too hard.
    By the way, a '55 to ''57 Chevy p***enger car rearend
    is a near bolt-in for your '50 Chev and was a common
    swap into these care 'back in day' when converting to
    more modern open drive-lines.
    Back to transmissions. If you'e really hung up on
    using the circa '55 to '62 "no-synchro on 1st'
    3-speed, go ahead but you've been forewarned -
    they're weak and don't really have anything
    particularly good going for them.
    Post '62 though, your choices for trannies are much
    better. By then.the available GM 3 speeds were all
    full-synchro, much stronger and much smoother
    shifting. 1st gear ratios for the 6 and V8 p***enger
    car and 1/2 ton truck applications were all similar
    and mostly in the 2.50 to 2.80 range, so not much
    difference there.The common '63 and up GM choices
    are the light-duty Saginaw 3-speed in either s normal
    3-speed or '3 speed with O/D' form. Not the best in
    my opinion, but acceptable with a 2.50-six that's not
    going to get beat on a whole lot - and if you can find
    one, the 3-speed with overdrive' version would be
    pretty cool and make for a good all-round cruiser.
    The other and probably better two choices would be the
    Munciei 3-speed used in some 6 and most V8 cars and
    light tricks from the mid-60's into the early '70's.and the
    heavy-duty Ford - yes Ford(!) - 3 speed top loader
    ****** that GM used for awhile in the late 60's with
    big-block/3-speed ****** equipped cars. Not too
    common even 'back in day' and even less so now, but
    they're out there if you look hard enough. All of these
    trannies- the Saginaw, the Muncie and GM -pattern'
    Ford 3-speeds are all side shift designs, had synchros
    on all three gears and are stronger,smoother shifting
    and easier to get parts for than the previous '55 to style
    '62 Chevy3-speeds Hope some of this helps.
    Mart3406
  22. BaltoBeater
    BaltoBeater
    I have installed a 700r4 behind my 230 so I'm not much help with this topic...but... I did pick up a new GM HEI from Langdon's Stovebolt for under $100 (not sure of total with shipping). He has a wealth of knowledge on this stuff. Good guy to talk to. Good Luck.
  23. Mr48chev
    I've got one of those later three speeds behind the 250 in my 48 and I'll tell you that the full syncro low gear sure makes it a lot more pleasant to drive. The early trans will work fine but the later one with the syncro low gear will make it a lot simpler to drive in traffic on a daily basis. NO grinding going into low when the car is rolling up to a stop and no making a full stop to get it into low.
    It sounds like a fun car that is going to scoot around town good and be able to make some serious road trips. The best thing about putting the 250 in is that you won't think twice about jumping in the car for road trip as they are dead nuts reliable plus pull decent mileage.
  24. JohnnyP.
    JohnnyP.
    funny that you mention an overdrive for the 3 speed, i have a buddy that has a few of these. tole me i can have the whole set up for $300 but i need to find an engine and trans first.
  25. mart3406
    mart3406
    from Canada
    If you want a '3-speed with O.D' I'd probably grab what your
    buddy's got now, while they're still available and wait and get
    your engine later. 250 Chevy six's are common and easy
    enough to find-- but not so the Chevy 3 speed with OD
    trannies- at least not when you actually want or need one.
    Mart3406
  26. JohnnyP.
    JohnnyP.
    these overdrives arent going anywhere. this guy holds on to them and im a friend that can actually get a part out of his hands:)
