chevy numbers
Discussion in 'The Hokey Ass Message Board' started by mr. dick, Aug 6, 2007.
  1. mr. dick
    mr. dick
    from New York
    To all you number gurus;
    I need some help decephering this chevy block. The only numbers I can come up with (cause my close vision really sucks) is on the passenger side of the block. numbers read as follows 18W327104 and VO5O1DE any help would be greatly apprieciated.
    Mr. Dick
  2. olddrags
    olddrags
    from ky
    I think that' s a 283 ??? I'll Ck tonight.
  3. Tony
    Tony
    I checked the suffix letter's on another web site and came up with these possibilities.
    This is the site they are from
    http://www.nastyz28.com/gm-chevy-codes/chevy-engine-codes-suffix-4.php
    <table border="1" width="100%"><tbody><tr><td>[FONT=Arial, Helvetica, sans-serif]DE [/FONT]</td> <td>[FONT=Arial, Helvetica, sans-serif]1958[/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]283 [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]Powrglid, air susp [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]- [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]- [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]- [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]full size/Malibu[/FONT]</td></tr></tbody></table><table border="1" width="100%"><tbody><tr><td>[FONT=Arial, Helvetica, sans-serif]DE [/FONT]</td> <td>[FONT=Arial, Helvetica, sans-serif]1962[/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]283 [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]Powerglide, a/c[/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]- [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]195 [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]- [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]A X[/FONT]</td></tr></tbody></table><table border="1" width="100%"><tbody><tr><td>[FONT=Arial, Helvetica, sans-serif]DE [/FONT]</td> <td>[FONT=Arial, Helvetica, sans-serif]1968[/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]307 [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]man trans., 4 spd [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]-[/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]200 [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]2 [/FONT]</td><td>[FONT=Arial, Helvetica, sans-serif]A F X[/FONT]</td></tr></tbody></table>
    I know you said you have a hard time seeing the number's, but can you get to the rear driver's side of the block for the casting number?
    Tony
  4. mr. dick
    mr. dick
    from New York
    Hi Tony
    Thanks for the help...unless Im an inch away I cant see the real small stuff.
    mr. Dick
  5. LowFat48
    LowFat48
    the casting #s behind the drivers side head are big , about 5/8`s inch tall
  6. LowFat48
    LowFat48
    heres a pic so you know what to look for
  7. squirrel
    the 18W....... number means it is a Chevy from the 1968 model year
    and I have a book that lists the DE code as a 67 chevelle 283 as well as a 68 chevelle 307.
    There should be another casting number on the back of the block that will tell you when it was made, a letter and two to 4 numbers, last digit would be the year. it will look like D 22 8 or something,
  8. bava17
    bava17
    hey Mr. Dick,
    i've always had really good luck with www.moretech.com
    just an FYI for ya.
    regards,
    steve
