Chevy oil filter adapter problem !
Discussion in 'The Hokey Ass Message Board' started by mtnman, May 26, 2013.
  1. mtnman
    mtnman
    Hey all.....new to HAMB. Here's my dilemma... I rebuilt a 1962 chevy 283 to install in my 1996 Chevy dually 4x4 stick trans. I knew I needed the factory oil filter adapter to make the oil filter clear the front driveshaft....picked one up from a 1993 350 chevy 4x4 truck in the local junkyard. It does not seat/seal up into the 283's oil filter cavity. The bolt holes lined up and I used a new gasket and O-ring....but when I hit the oil pump drive shaft in the distributor hole with the drill to give it a priming, the oil began leaking heavily around the adapter within 5 seconds of drill spinning. Did I somehow miss another part from the junkyard engine which I need?
    My 16 year old son and I have been rebuilding this engine all winter as money allowed...we are both chomping at the bit to hear it purr....we want to get it off the engine stand and into the truck already. Anyone done this before with older chevy engines ? Any other suggestions?
  2. using the later spin on adapter/oil byp*** on a 283 does not work as you have found out. you need to use your old byp*** with an aftermarket adapter like Wix # 24061
  3. you need this , along with your old byp***
    this is what the byp*** valve looks like , you need to use both together
    Nailhead A-V8 likes this.
  4. BobF
    BobF
    from Poway, CA
    I rebuilt a 60's 283 for our truck and I recall I had to get a adapter and a gasket from a cartridge filter and bolt it up with the two 5/16" bolts to use a spin on filter.
  5. dave lewis
    dave lewis
    from Nampa ID
    36 3 window has it 100% correct.
    Dave
  6. Bowtie Coupe
    Bowtie Coupe
    Yup, 36-3 Window is right on the money. Trans Dapt #1059 is another spin-on oil filter adapter. Fits 56-67 SBC. You can find them at Pep Boys, Advance Auto, and other places, too, I'm sure.
    lothiandon1940 likes this.
  7. kracker36
    kracker36
    Should have put a small block Ford in it.:p
  8. Mr Gasket has one too , their part # 1270 , but in the past i've had trouble with them leaking. that's why i prefer the Wix....i've used several of them with no problems
  9. junkyard junky
    junkyard junky
    Used the same adapter kit on my 283 in my 62 Belair wagon
  10. Normal Norman
    Normal Norman
    from Goshen IN.
    Mtnman, Please do an introduction.
  11. skinnydude
    skinnydude
    Spend only a few dollars in the beginning and it will pay off in the end. I know
  12. Mr48chev
  13. Mr48chev
    It's bad enough that he building what is going to be a gutless wonder that cost twice to build as what a 350 would have let along have a smart ***ed remark from the peanut gallery.
  14. kracker36
    kracker36
    Sure, But its totally cool here for a "high post count" member to spout off about running a 350 when someone mentions oil filter clearance issues with a 289 or 302. P*** the peanuts please.
  15. GassersGarage
    GassersGarage
    What I don't get is why you would put such a small engine in a dually and why talk about a '96 Chevy on this forum.
  16. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    No intro, and a 96 Dually on the Hamb? I guess traditional is getting redefined :rolleyes:
  17. OK; let's sort this out for you, the spin-on adapter uses longer bolts so that it can reach through the spin-on adapter and the original by-p*** thing, but,,, you will need to sandwich the oil cooler adapter on top of that so,,, you will need some even longer bolts. This should work as long as the square-cut O'ring is first (as in against the block). However, all this **** stacked up may create a situation where the oil filter comes in contact with something? In that case you could use the shorter oil filter for the p***enger cars. It is half the length. Hope this helps!
  18. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    First off your first post belongs in the introduction forum.
    A 283 is a good motor but it's going to be a gutless wonder in a big truck like that but if your 16 year old is going to be driving it, it may not be a bad idea. Wont be getting many speeding tickets except in school zones.
  19. Well guys, It is an old motor and maybe it's for his tow vehicle, and I understand that intros are not required anymore,,,,,,,,,
  20. 56sedandelivery
    56sedandelivery
    Some of the spin-on conversion kits do away with the stock by-p*** valve, but then use a FORD application spin-on filter that has a built-in, by-p*** valve. If I'm not completely correct on this, someone will expand on it. Maybe the 283 is just a temporary replacement engine. Lets just hope he uses the dually to haul "old" parts with. Butch/56sedandelivery.
  21. mtnman
    mtnman
    I thank you ALL for your responses ! To add info though , this truck will be used sporadically for things such as towing other cars on our tow dolly....hauling coal....firewood....and pulling a 32 foot camper to some local campgrounds. It will not be a daily driver. The country backroads in the area where I live ( mostly mtns ) don't allow me to get up past 55 mph. The 4.10 gears, mild cam and edelbrock 4 bbl with the granny low 4 speed are about all I need. My main concern was clearing that front driveshaft. I apologize for not being computer site savvy.
  22. Mr 48 . I came here with the same problem Mtn man Summit description[ your link] says this
    """"Not for use in 283 or 327 equipped Chevy II. """"
    I have the original piece [ was on another engine ][​IMG] http://www.jegs.com/i/Melling/689/M...mCfx2NirLbwJrCuD_5Dz5ao9vCT81nvAaAq59EALw_wcB and can not figure out what pieces are needed for what kits mentioned .. I am working with a 1966 283 out of Chevelle.....any ones help will be extremely appreciated....
    Thanks
    Dan
  23. I forgot to mention that I am try to install a Mr. Gasket #1270 also
