chevy question
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by channel cat, Dec 27, 2008.
  1. channel cat
    channel cat
    I have always been into cool cars, at least the customizing end of it but I have never completely rebuilt my own engine.I now plan to attempt that.I plan to build one of 2 engines that I have.One is a 67 chevy 283 and the other a 71 chevy 350. for my model a coupe.I would prefer the bigger cubes of the 350 but I like the vintage look of the 283. My question is,can I build the 350 without the unsightly look of pcv coming out the valve covers?Ialso have an older edelbrock 3 deuce intake with oil breather filler tube that I plan to install.
  2. kman1932
    kman1932
    If you put 1 push in style breather in each valve cover and a breather in the filler tube you will have adequate ventilation. Don't use just the one on the filler tube. Also, I think you would get better response on this thread if you were to put in the general discussion and not the introduction forum. Hope this helps, Chuck.
  3. ken1939
    ken1939
    I think kay covered it :)
  4. 53sled
    53sled
    from KCMO
    99% of people in this world can't tell a 350 from a 283 or an aftermarket 454 stroker small block just by looking. do whatever gets you going.
    motors with that breather tube usually had road draft tubes as well. do a search for hidden pcv
  5. screwball
    screwball
    welcome from Finch Ont about 15 min north of you.
