Hot Rods Chevy small block 3x2 intake
Discussion in 'The Hokey Ass Message Board' started by John Milner, Apr 20, 2020.
  1. John Milner
    John Milner
    from Oklahoma
    Is there a small block tripower intake that uses the large base Rochester carbs?
  2. jimmy six
    jimmy six
    None I ever saw or had. I do believe there weren't some type of adapter for the ones that took 3 bolt style.
  3. Fordors
    Fordors
    Offenhauser made them, I sold a NOS one a few years ago. It may still be cataloged but I don’t know. 68D69AE5-95F3-4FD8-816C-06491D0D0428.jpeg
    Deuces and jimmy six like this.
  4. B.SUTTON
    B.SUTTON
    from Peoria, IL
    Fordors is correct. Offenhauser makes them - or at least they did when I bought a new one 2 or 3 years ago. I set mine up with factory Pontiac early tri-power carbs, which use a small base carb for the primary (center) carb and large base carbs for the secondaries. I was able to locate a seller on eBay that machined large to small base adapters as well as large base risers all the same height so I could install all three carbs on the Offy large base manifold.
    jimmy six likes this.
  5. John Milner
    John Milner
    from Oklahoma
    Great, where did you buy yours b.sutton? I looked on speedway and summit racing and just saw a small base available.
  6. Blues4U
    Blues4U
    from So Cal
    Is the large base Rochester the same bolt pattern as Holley 2300?
  7. B.SUTTON
    B.SUTTON
    from Peoria, IL
    Sorry for the delayed response. I bought mine from a local guy that is an Offy dealer/vendor. You might try these guys: https://www.exeterautosupply.com/
    I’ve attached a picture of mine with the risers/adapters. Additionally, I believe I used a thermostat housing for a tri-5 Chevy. That front carb is a close fit, even with the riser.
    tb33anda3rd and John Milner like this.
  8. John Milner
    John Milner
    from Oklahoma
    I will give him a try and see if they have anymore. Thanks for the help. If anyone reading this has a good used one I would be a buyer for it. Thanks
  9. moparboy440
    moparboy440
    from Finland
    Offenhauser 5254
