Hot Rods Chevy Smallblock harmonic balancer
Discussion in 'The Hokey Ass Message Board' started by drew1987, Aug 9, 2016.
  1. drew1987
    drew1987
    Hello,
    I purchased a brand new harmonic balancer for a 73 350. Never used it. Now I have an 85 350 and need one. The part numbers are different on an online source, but are they interchangeable?
    Thanks
    Drew
    Member:
    Rochester Street Rods - Est. 1970 http://www.rochesterstreetrods.org
    CrossMembers Car Club - Hebrews 12:2 http://www.crossmemberscc.com
  2. bonzo-1
    bonzo-1
    It will fit but the timing marks may not be right for your timing cover.
  3. squirrel
    you can fix the timing mark thing pretty easily. Also check the diameter, it may not match the timing marker. You can get aftermarket timing tabs to fit either one, right?
  4. 57 HEAP
    57 HEAP
    Check the inside diameter and keyway size. Check the keyway location to the timing mark on the outside diameter. Check the outside diameter and pulley bolt hole locations. Check the bolt hole sizes, they might be metric on the newer balance, so the diameter might be different.
    The timing tab on the front cover can be removed if need be so that TDC lines up with the mark on the balance. Some types bolt on, others are welded on.
  5. Mike VV
    Mike VV
    from SoCal
    As has been somewhat noted.
    1. Yes, it will fit.
    2. Yes it will dampen the harmonics.
    3. Yes, a 350 to 350 damper will be balanced, close, not exactly. Exact requires proper balancing work with the engine apart.
    4. Verify that the timing mark is where the "original" mark is. If it is not, there is a couple of ways to make a properly placed groove in your new damper. By using math or the more accurate but more time consuming way, by checking the actual crankshaft position.
    5. The cranks are all the same diameter.
    6. The seals are all the same diameter.
    You'll be fine.
    Mike
  6. drew1987
    drew1987
  7. drew1987
    drew1987
    How likely is it that mine has failed? I get a pulsating vibration at 45 to 60 mph. It's like a woob.....woob.....woob.....woob..... spaced out maybe two or 2 1/2 pulses per second. At first, I thought it was driveline… When I first finish building the car… But if I pop the car in neutral, once the engine settles down to idle, it goes away. Furthermore, with the car in park or neutral, reving the engine to similar rpm's at a dead stop will produce the same pulses
    It is a junkyard motor that I don't know too much history about… Pulls good vacuum, for the most part steady vacuum, doesn't leak or burn much if any oil, and goes down the road just fine for the few hundred dollars it cost. I can't afford better
    Member:
  8. squirrel
    The damper is there to dampen torsional vibrations in the crankshaft. It is not a "balancer", even though that's what folks call it.
    Sounds like a driveline vibration, to me. But there could be some engine vibration going on, also.
    How bad is it? Mine all seem to shake a little bit at some speed, or another. I just keep driving them, unless it's pretty bad.
  9. BJR
    BJR
    "Furthermore, with the car in park or neutral, reving the engine to similar rpm's at a dead stop will produce the same pulses"
    Not driveline.
  10. drew1987
    drew1987
  11. squirrel
    I know he said that, but it still sounds like a driveline vibration, in addition to a small engine vibration. Without being there, neither one of us can rule out anything.
  12. Engine man
    Engine man
    from Wisconsin
    I've never heard of a driveline vibration in with the transmission in park. Are you sure it's a 350 and not a 400? Did the flexplate come with the motor? A 400 will have an extra weight on the flexplate. If you put a 350 flexplate on it, you will have a shake but it is usually noticeable at idle too. A 400 will have a notch in the outside of the damper.
    squirrel likes this.
  13. drew1987
    drew1987
  14. drew1987
    drew1987
    We can definitely rule out drive line for now cause it does it in park. If I fox that and it still pulses at speed then it's s driveline too. My pinion angles are good, other then possible metal to metal at the ****** mount (which still doesn't explain the pulse) I can't imagine it not being in the motor. The mount is isolated with rubber under and over, but the through bolts might touch the holes through the mount
    Is it likely that it could be a worn or damaged damper?
    Member:
  15. squirrel
    It's not very likely, but it's possible. The damper was balanced when it was made and if the ring slips on the hub, it can be out of balance. The torque converter is more likely to be out of balance.
  16. drew1987
    drew1987
  17. slowmotion
    slowmotion
    Is the engine in good state of tune, vacuum lines etc..? A sketchy wire or plug etc, can cause a slight miss that may cause some bad vibes. You did say it was a junkyard motor.
  18. Ebbsspeed
    Ebbsspeed
    Normally a "woob woob woob" vibration (good word, did you make it up?) is a harmonic vibration caused by a couple things being out of balance, and rotating at different speeds. For instance, if your engine fan and your harmonic damper both have a little imbalance, there are times when those imbalances will cancel each other, and times when they are additive. You could remove the accessory belts and see if it still vibrates.
    squirrel and slowmotion like this.
  19. drew1987
    drew1987
    The wires and plugs are new… The distributor is used, everything is in tune. I have been chasing an ever so slight Lee fluctuating Idol… That is, RPMs/vacuum will wander a little bit… Not fast like a leaking valve, but slow
    Member:
  20. drew1987
    drew1987
    I suppose I could try to illuminate each one of these things… I don't know how I would eliminate a miss or a torque converter, but if it gets better with the fan and water pump disconnected, that will tell me something
    Member:
  21. badvolvo
    badvolvo
    Inspect it closely, look for cracked rubber or the outer ring alignment.
    I have a 350 in a 36 chevy, i bought the motor already built, it was all new, with receipts. However, the engine was never as smooth running as it should be. During a recent inspection, i thought the balancer was coming unglued so i ordered a new one. Once i removed the old one, i saw it was made that way. I had the new SFI approved fluid damper so i installed it anyway. Glad i did, the thing runs much smoother with the new fluid damper than it did before. turned out to be a nice upgrade. I can tell the difference at almost any RPM.
  22. hotroddon
    hotroddon
    If you need to check if the balancer has slipped, get a dead stop, find true TDC and compare to your balancer timing mark. Easy as pie.
  23. drew1987
    drew1987
    What's a dead stop? And thanks.
    ***uming a tool for finding tdc- I could always fit the top of the travel and then turn the other way and find it again and take the average, yes?
    I did just find a small manifold leak and thought it went away. It's smoother but not like it should be.
    Also I figure I could Eliminate the torque converter by unbolting it from the flex plate and sliding it in.
    Member:
  24. squirrel
    you described a dead stop! :)
  25. drew1987
    drew1987
    Oh! Still probly tough to do accurately. And this means pulling all my plugs
    So is it possible every small block's dampener the same? There are many part numbers but is it all markings? Cause a 1973 350
    And a 1985 one are different motors yes!?
    Member:
  26. squirrel
    Small block dampers changed over the years, and for different size engines. Most of the 350s used either the small one or the big one, there were two common ones. later ones often had the timing mark in a different place.
    only need to pull the #1 or #6 plug to find TDC
  27. 47ragtop
    47ragtop
    I had a similar vibration problem . Turned out to be either the torque converter or flywheel. I just replaced both at the same time. You might try unbolting the convertor and moving it around 120 degrees and see if that makes a difference ( much easier than replacing the flywheel or convertor.
  28. Ebbsspeed
    Ebbsspeed
    @47ragtop makes an excellent suggestion regarding re-clocking the torque converter to the flex plate. Never thought of it, but it's a great idea.
  29. drew1987
    drew1987
    The torque converter idea is good. I was going to unbolted anyway… I also remember torquing each one of those three bolts fully, then moving to the next. Perhaps something is bound up because of that… Should have torqued one at a time a little bit each.
    I will try this and report back, just as soon as I have the ability to get under my car.
    Squirrel, it's really hard to turn over my engine with the plugs in because of how difficult it is to get to the bolt on the harmonic balancer. Much easier if I take out all the plugs, unfortunately.
    Somebody once said to me "those early Chevy's were not in anyway shape or form intended to have a V-8 in them" they were correct… But boy is it a lot more enjoyable! It's true, because if you look at the same year Pontiac, or Buick, it was an easier swap. That is a vague, blanket statement… But it's true.
    Member:
