Technical chevy smallblock in a 29 ford
Discussion in 'Traditional Hot Rods' started by Deuce Man, Aug 6, 2020.
  1. Deuce Man
    Deuce Man
    This swap has probably been done thousands of times, but not by me. I think I might have to push the firewall back some, but would rather not disturb the tank if possible. I would love some advice from you guys that have done this. Thanks Rich
  2. 325w
    325w
    The lower part of the firewall have to be set back
  3. Deuce Man
    Deuce Man
    Does anybody have any good pictures of a 29 with a smallblock sitting in place? a picture is worth what? Thanks Rich
  4. oldsman41
    oldsman41
    Do a search there are lots of build threads.just about any v6 v8 has to have a notch below the gas tank
  5. warhorseracing
    warhorseracing
    from cameron wv
    Again!
  6. Blues4U
    Blues4U
    from So Cal
    ^^ That's not helpful....
  7. Marty Strode
    Marty Strode
    Here is mine, the engine is a tad further back than it needs to be. The problem you might have is removing the distributor with the stock tank, that would worry me. IMG_4925.JPG
  8. Deuce Man
    Deuce Man
    Marty, thanks for the picture. Where is the crankshaft centerline in relation to the top of the frame rails? Thanks Rich
  9. Marty Strode
    Marty Strode
    Rich, The crank C/L is 1/2" below the top of the rail. It's a tad higher than most, but this is a race/street application. IMG_4161.JPG
  10. Montana1
    Montana1
    Maybe you should have...
    loudbang and -Brent- like this.
  11. Roothawg
    Roothawg
    My pee pee feels funny when I look at this truck.
  12. Marty Strode
    Marty Strode
    I hope to be back on it soon, thanks for your interest.
    loudbang and Roothawg like this.
  13. RmK57
    RmK57
    Wouldn't have to worry about removing the distributor if it were in right place to start with, right?
  14. Pete1
    Pete1
    from Wa.
    This one has the stock tank. I fabricated an indent for the distributor. A engine bay.png
  15. Dave Mc
    Dave Mc
    not a Chevy , but it is a small block in my 29 P.U.
  16. Grandadeo
    Grandadeo
    Rich are you engine swapping the pickup or starting a new project?
    Lee
  17. Grandadeo
    Grandadeo
    Me again. Been so long since we all got together I forgot about the yellow roadster. Out with in 4 in with the 8?
  18. scrap metal 48
    scrap metal 48
    On a model A frame, If you set the motor to run a mechanical fan( not low in the frame) you have to recess the top part of the fire wall too.. If you recess the bottom fire wall about 3 1/2", You can recess the top firewall for the distributor about 2 1/2" before you hit the gas tank.. Not a very good pic but you sort of get the idea... **clic pic** for sale pics II 007.JPG
    loudbang, Dave Mc and Tim like this.
  19. scrap metal 48
    scrap metal 48
    On a 32 frame, you don't have to recess firewall at all.. **clic pic** 100_0241.JPG
  20. Tim
    Tim
    from KCMO
    I was going to mention it but got beat to the punch! You’ve got a couple inches you could clearance the upper for the distributor to come out before you would hit the gas tank.
    loudbang and scrap metal 48 like this.
  21. Metal Mover
    Metal Mover
    from Jamul CA
    I have a 29 roadster with a sbc since 1965, rebuilt it in 90's and put in a *****in firewall & gas tank front, (tank was gone) and I should have put a relief in the tank front. Working on the distributor is a huge pain, removal is a very large project. Thankfully I converted to Pertronix a few years back. Unless your heavily invested in the chevy I'd go with the ford. The center line on the crank is about 1" below the top rail.
    My opinion, just like belly ****ons, everyone has one. IMG_1685.jpg IMG_1686.jpg
    loudbang and brEad like this.
  22. Marty Strode
    Marty Strode
    Yeah, but that's a Lincoln engine.
  23. Montana1
    Montana1
    Especially if they put the gas tank out back...
  24. Baumi
    Baumi
    I fixed it for you :)
  25. Deuce Man
    Deuce Man
    My 29 roadster is hurtin for legroom to begin with If I recess the firewall much it will be worse. Smallblock fords have so much "stuff"on the front You have to set them even further back. How about two small electric fans, one above the waterpump pulley and one below this allowing the engine to set in front of the firewall instead of back into it? By the way, the Lincoln valve covers look great on that chevy. Hey Lee hope this covid thing gets solved soon so we can get back to Friday morning breakfasts with the guys. Thanks for the response guys! Rich
  26. Blues4U
    Blues4U
    from So Cal
    That's a 30/31, not a 29.
  27. Montana1
    Montana1
    I like a Model A on a '32 rail. I fixes a lot of the problems. :cool:
  28. scrap metal 48
    scrap metal 48
    I personally think model A's make better hot rods on model A frames with stock grille shells.... **clic pic** MR 800 for sale 012.JPG
    Raunchy, loudbang, 1oldtimer and 6 others like this.
  29. el Scotto
    el Scotto
    from Tracy, CA
    Thats one of them cross dressing Chevy engines, you know, the ones wearing women’s underwear to feel pretty... :D
  30. badshifter
    badshifter
    IMG_2317.JPG IMG_2318.JPG IMG_2317.JPG IMG_2318.JPG IMG_2323.JPG IMG_2324.JPG IMG_2327.JPG IMG_2328.JPG IMG_2478.JPG
    Done correctly you don't lose foot room still use the stock tank, run a mechanical fan, and you can pull the distributor. Stock hood, radiator location etc.
    I made the section above the distributor removable.
    Von Dago, Jet96, loudbang and 7 others like this.
