Chevy T-5 Question
Discussion in 'The Hokey Ass Message Board' started by 30chevy, May 15, 2008.
  1. 30chevy
    30chevy
    from Kentucky
    Can anyone tell me if a chevy T-5 from a 2.5 S-10 will bolt up to a chevy 292 inline 6 bell housing?I don't have a T-5 to measure to check before I buy one. Thanks
  2. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Intro please! Let us know a bit about yourself and your car. This isn't "ask Jeeves" my friend. But I am sure that someone will know the answer to your question and welcome.
  3. 18n57
    18n57
    Pre '93 S-10 5 speeds have same bolt pattern as most other GM tranny's should bolt on no problems. Check all the great T5 articles in the tech archive. TONS of info.......................
  4. Flat Ernie
    Flat Ernie
    Tech Editor
    Check the link in my sig line...
  5. Snarl
    Snarl
    If it has the normal Chevy bolt pattern, and the center hole on the bellhousing is the typical 4 11/16", then yes, with slight modifications to the length on the input shaft and collar, and run a 1/2" drill bit through the bolt holes on the tranny. Different clutch disc is needed also. Make sure you have the correct speedo setup as electric and cable drives are not interchangeable on S10 versions.
