Chevy Tilt Telescoping Steering wheel
Discussion in 'The Hokey Ass Message Board' started by bustingear, Jul 3, 2010.
  1. bustingear
    bustingear
    Can anyone tell me how to get the final plate down on the spline spring so I can get the U clip in? It is a real challange with the telescoping center that comes out when you use the spring compressor. There is no stop for it and the center of the spline slides out. Help GM tech!
  2. joel torres
    joel torres
    lol i have the same problem right now im ready to buy a new column all i did was change the lock
  3. Mr48chev
    Got a buddy with real strong thumbs? I just looked in the Cadillac manual sitting beside the chair and it doesn't show how to do it.
  4. bustingear
    bustingear
    I just read where ther are two kinds of spring compressors one for reg tilt and one for telescoping tilt Try to find one right! Anyone else with whirly gig solution?
  5. bustingear
    bustingear
  6. bustingear
    bustingear
    still cant get it to lock. Whats the trick
  7. bustingear
    bustingear
    Pulled the rod and it was bent. I will try a drill bit in place and see is I can tighten it enough to use the spring plate tool. I dont count on much however.
  8. GMBOWTYE
    GMBOWTYE
    from Ames IA
    take a peice of 5/16 all thread and cut it off so you can tighten the lock in the middle of the steering shaft with a pliers and then use your lock plate remover . you can also use a peice of rod down the middle of the steering shaft and tighten the lockplate remover tool tight to lock the telescoing part in,not extended and remove u clip
  9. joel torres
    joel torres
    interesting link now why didn't i think of that dam can't wait to do it now
