chevy vin tag
Discussion in 'The Hokey Ass Message Board' started by iamspencer, Oct 15, 2008.
  1. iamspencer
    iamspencer
    when i chopped my 54 chevy i destroyed my vin tag that was on the door frame so its not like i can even re rivet it on or anyting
    anyone have this problem before
    can i get a repro of it if i knwo the number
    thanks
  2. bobwop
    bobwop
    from Arley, AL
    some states will issue a new tag, but the number won't match and the ***le will have to be re-issued
    I found a guy that will do me a tag for $15...I think I found him in the Misc. Cl***ifieds. Does not look original, but does it matter?
  3. iamspencer
    iamspencer
    i dont even have a ***le
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    that could prove to be fun..depending on the person you deal with at your local DMV
    did you keep the remains of the original tag?
  5. bobwop
    bobwop
    from Arley, AL
    tell the DMV you bought it from a non-***le State, such as Alabama or New Jersey.
    If you have the original engine, the serial number on the engine is likely the VIN
  6. squirrel
    nope, I've always treated VIN tags with the respect they deserve.
    Sorry I can't help. You're probably going to have a lot of fun at DMV. Put a lawyer on retainer.
  7. filthy frank
    filthy frank
    55 chevys has a vin on the frame,drivers side, on top, check your frame. filthy frank.
  8. Gusaroo
    Gusaroo
    do a search for "historical do***entation"
  9. F&J
    F&J
    CT does not require a ***le on oldies. IF that vin tag on a 54 chevy is like my friends 48, it was actually a body number. CT inspectors at the Willimantic office allowed him to use the motor number on his stock 48. It seems to depend on who looks at it and if the planets are aligned :) .......OR....some smog garages in CT do VIN checks on old cars....find a friendly one
  10. Salty
    Salty
    from Florida
    I'm with Squirrel...why the hell would you cut a a VIN plate?
    I still have the original for my 49, it was previously abused and mistreated by the previous owner BUT I had the original ***le...I recently got a repop VIN plate and had the VIN restamped in it...BUT still kept the original just in case, even though its a hunk of twisted **** (still readable though)
  11. fisher
    fisher
    where did you get the repop VIN plate???
  12. jscoma47
    jscoma47
    If you have the # then go thru a place like ITS,ITS-***les.com. for the relative cost,less than $200 you get a registration that is fully transferable to you.
  13. old dirt tracker
    old dirt tracker
    from phoenix
    54 has no vin on the frame 55 was the first year.work with your mvd is the best.gameplaying will just make it worse.
