Chevy Webers
Discussion in 'The Hokey Ass Message Board' started by Dave Wolin, Jun 21, 2010.
  1. Dave Wolin
    Dave Wolin
    Has anyone found a good way to adapt a pre '86 style intake to vortec heads ? I'm trying to put a set of webers on my vortec head crate motor.
  2. Yea you just slot the center holes.
  3. hotroddon
    hotroddon
    Is that Dave Wolin that used to race Mitsubishi's??
  4. hot rod pro
    hot rod pro
    from spring tx.
    does your heads have 4 intake bolts per side or 6?
    late vortec heads have 4 per side and they are vertical not square to the intake ports.
    early vortec heads have 6 per side with just the two center bolts being vertical.
    -danny
  5. 53sled
    53sled
    from KCMO
    Die grinder.
  6. need louvers ?
    need louvers ?
    When these heads first became the hot tip about 7 or 8 years ago I know Scoggin ****y Chev out of I believe Texas was re-machining them to accept standard older Chevy intakes. I don't know if that is still the case, or if they are still in business, but you might google them and see. Worse comes to worse, if you need me to I can dig through many years of Car Craft to find the article if you need. Just give me a P.M.
  7. I did it on mine. Bolted a mid sixties Offy Tri-Power intake to a set of 92 heads and just slotted the holes in the intake and used 4 wedge washers. works perfect. As long as you have the 6 hole heads ( pre 96 I believe ) no problem!!!!
  8. need louvers ?
    need louvers ?
    You are talking the Vortec heads with the vertical manifold bolts right? If so the Scoggin ****ey deal is the only one I know of. I'm pretty sure they plugged the holes for the vertical attachment and redrilled for the old style pattern. I've seen allot of answers here saying to slot the holes and go, but I'm pretty sure that doesn't apply to the actual Vortec head, just the center bolt style.
  9. Dave Wolin
    Dave Wolin
    Yep, that's me !!
  10. Dave Wolin
    Dave Wolin
    It's the 4 bolt style late vortec. I'm ready to stick a manifold in the mill, machine the top off and weld on weber flangers - there must be an easier way.
  11. sdluck
    sdluck
    Why not redrill the heads?
