Technical CHEVY WOODSTRUKTURE
Discussion in 'Traditional Hot Rods' started by Steffen Jobst, Jan 3, 2017.
  1. Steffen Jobst
    Steffen Jobst
    When I wanna swap a SB in 20/30ties chevy , what about the woodstrukture in the body?
    Can I remove the wood?
    Must I make it stronger?
    Must I replace it?
  2. nunattax
    nunattax
    POST UP A PICTURE,
  3. R Pope
    R Pope
    You "can" remove the wood, but the body will fall apart! The wood is the structure, the tin is just a skin. That's why you don't see a whole lot of old Chevy street rods.
    scrap metal 48 and Steffen Jobst like this.
  4. Atwater Mike
    Atwater Mike
    Yeah...Old Chevies are like Ford Woodies. Inside-OUT!
    tb33anda3rd and Steffen Jobst like this.
  5. Greg in Jax
    Greg in Jax
    Just be sure that the wood is not rotten or loose and it will be fine. It MUST be there, as R Pope above told you. This Bantam is also sheet metal over wood.
    Steffen Jobst likes this.
  6. wraymen
    wraymen
    Wood kits are expensive, you can make your own or build a metal frame if it needs replacing. Just to give you an idea, I found receipts for a complete wood kit for a 27 truck and it was over $3,ooo. This is just the cab, no bed and it was dated 2006.
  7. Steffen Jobst likes this.
  8. tb33anda3rd
    tb33anda3rd
    the wood can be replaced with metal, cheaper, quicker and easier [maybe] .
    that being said i believe new or good wood structure in the car is better. wood absorbs impacts better.wood absorbs vibration and shock better making for a more solid and quiet ride. the wood can be made using basic tools....it just takes time.
    full disclosure : i have a 33 chevy with all it's wood structure.
    Steffen Jobst and Texas Webb like this.
  9. Ghost28
    Ghost28
    Most of the old chevy bodies I have built didn't have any wood for patterns so steel is what I do to them.
  10. sloppy jalopies
    sloppy jalopies
    Because the wood subfloor rots faster than a steel subfloor it doesn't hold **** as long, it doesn't rot / rust the skins from the floor up... the steel floor lets leaves and pine needles build up with time and hold moisture... i have seen dead chebbies that have fallen apart... the panels dropped and fell away from the frame... most not needing any patch panels...[being a ford guy i let them rest in piece...]
    some fords used wooded sub-structures ... like a '30-'31 vicky...
  11. Steffen Jobst
    Steffen Jobst
    Hi nunattax,
    sorry I have yet no pics. Start the project in spring. Now it's deep deep in the garage...
