Technical Chipped cam distributor drive gear
Discussion in 'The Hokey Ass Message Board' started by Rogue_Rider, Sep 27, 2023.
  1. Rogue_Rider
    Rogue_Rider
    from Colorado
    F683F0F5-9AF3-47C8-B561-184B96F1F02D.jpeg Anyone else ever run into this problem before? Can this just be dressed out and ran or is it junk now? It’s not a huge chunk but it’s no inconsequential either. Thanks for any input
  2. squirrel
    is that a fresh never run engine?
    Oneball and seb fontana like this.
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    Looks like junk to me. I wouldn't run it.
    Rogue_Rider likes this.
  4. Rogue_Rider
    Rogue_Rider
    from Colorado
    No this is a used engine
  5. 427 sleeper
    427 sleeper
    I'd be concerned where the piece's went.
  6. inthweedz
    inthweedz
    If it's the 'silver' mark at the lower end of that tooth, I wouldn't worry about it, the cam driving the gear is usually contacts in the middle area of the tooth..
    As for where the chip went?? It might have come out during an oil change, or you could fit a magnetic sump plug..
    It looks too big to get thru the gauze in the oil pump pickup.
    guthriesmith likes this.
  7. miker98038
    miker98038
    Just to further my education, how do you chip a cam gear?
    X38 and 427 sleeper like this.
  8. RodStRace
    RodStRace
    Just like any hard metal part that also operates against another hard part with tight tolerances. Clumsy installation, something gets caught between the meshing parts, or something big enough and with enough force hits the part. It could also happen if lube is required but lacking (would show as heat which is not present here), or the part is flawed and normal stress causes failure. I think that covers it.
  9. Budget36
    Budget36
    May I ask what prompted a look to actually find the chip?
  10. Budget36
    Budget36
    Sorry, did have time to finish my request.
    I’ve never had a need to shine a light down the hole and rotate the engine to inspect the gear. I’d ***ume you had a need to do that, so I’m wondering what issue the engine had that could be related?
    Thanks.
    427 sleeper and Truckdoctor Andy like this.
  11. guthriesmith
    guthriesmith
    I guess I am not seeing a big issue from the pic. Chances are it has run for a long time already and will continue to run a long time.
    Truckdoctor Andy likes this.
  12. Budget36
    Budget36
    I’m not so sure about it running a long time like that. The “clean” of the chip as well as what appears to look the same (albeit smaller) little breakage/chipping on the teeth about 180 degrees from the chip.
  13. Oneball
    Oneball
    I guess @squirrel is thinking what I’m thinking; there’s an oiling problem with that engine. Why is the cam dry and dusty looking if it’s an engine that been run?
  14. X38
    X38
    What they said.
  15. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Being completely dry and clean in a used engine indicates an oiling problem that needs to be addressed. Then the gear itself needs replacement. I'd also want to look at the cam gear as well. Continuing with what you have most likely will cause bigger problems later on.
