Technical Choke Cable with Braided Center. Source?
Discussion in 'The Hokey Ass Message Board' started by BJR, Dec 13, 2025.
  1. BJR
    BJR
    I need to buy 3 choke type cables for a backup electric trunk release and backup shaved electric door release. They need to be at least 6 feet long and have a braided, not solid wire center. The solid wire center ones are not flexible enough for what I need. So far most of the ads do not specify if the center is braided or solid wire. Has anyone found a source for these, that will not brake the bank?
    Tow Truck Tom likes this.
  2. K13
    K13
    Hood or trunk release cables are almost always braided. You might try looking at those rather than at choke cables.
    Tow Truck Tom, BJR and VANDENPLAS like this.
  3. osut362
    osut362
    from East Texas
    I used 10 speed bike cables on my set up. Had to order them from a bike shop.
    Tow Truck Tom, BigRRR, BJR and 2 others like this.
  4. THIS ! I did this a few times over the years for different things .
    Custom lengths , braided and nylon casing super flexible .
    Tow Truck Tom and BJR like this.
  5. lostone
    lostone
    from kansas
    Same here, bicycle cables, and you can find different parts, ends and brackets for them.
    Tow Truck Tom, BJR and seb fontana like this.
  6. kabinenroller
    kabinenroller
    If you want a choke type cable because it has a knob and mounting threads you can remove the inner solid core and replace it with 1/16” wire rope. I have done this many times for use in microcars. Just solder the ends of the cable to the choke knob shaft and use a crimp on the end where it meets the trunk latch.
    Tow Truck Tom, vtx1800 and BJR like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    If you are going to use it as a backup for the doors, (mounted through the firewall , along the door hinge, into the door and to the latch) I would recommend a hood release cable. Just go to the junkyard and get one
  8. Happydaze
    Happydaze
    I've had great success at a local (to me!) control cable suppliers / makers. Incredibly inexpensive too!
    Chris
  9. BJR
    BJR
    If it was summer I would be at my local junk yard. But sadly it's winter and at the moment -4 degrees. So I need to order a cable from somewhere.
  10. rockable
    rockable
    Tow Truck Tom and 327-365hp like this.
