Sold . 1946 ford coupe, roof chopped all gl*** installed. Door tops rounded, deleted drip rails, shaved handles emblems trunk. Molded rear fenders and splash, recessed license plate box and custom taillights. Steel skirts. Camaro clip power disc brakes up front with brand new booster and master cyl, brake lines flushed and new rubber brake hoses. Power steering. 10 bolt rear parellel leafs 4” blocks, heavy mono leaf kit, Mini frame notch, rear shock crossmember w/ 1980 corvette shocks. (Shorties). 327 motor with new avs edelbrock carb, 350 trans. Brand new chrome tilt column with column shift. mostly new dash chrome, new moon 3 gauge setup recessed where radio was, new carpet kit, new home jobber interior side panels, no headliner. Ron Francis wire kit. Factory gauges restored and. ready to receive 12v but haven’t hooked. Car was originally customized in 80’s. I purchased months ago and did a makeover and got it drivable again. Paint is suede job body and paint not perfect but very presentable. Seats were in car when purchased so chose to do inside in browns, not sure what they are from. Clean ca ***le, last registered 1989 so out of system no back fees. I’ve Only driven around minimally havent takin on freeway. I’m sure there will be some small bugs to work out I don’t have time to keep working on it as I have other projects I want to focus on,
