Chopped 56 F100 (off topic engine)
Discussion in 'Off Topic Cars, Parts, & Antiquities' started by 123, Nov 30, 2025.
  1. 123
    123
    from Seattle
    City: Renton
    State: Washington
    Price: $12,500 ob
    1956 Ford F-100
    -Chopped 4"
    -73 Torino subframe w/disc brakes
    -Ford 8.8 posi 3.73 gears w/disc brakes
    -4 link with coilovers
    -5.3 LS engine
    -4l60e transmission
    -Custom front sump oil pan
    -Flanders LS swap custom engine/****** plug and play harness that mounts the pcm behind the seat.
    -Brand new EZ Wire 21 circuit wire harness for the truck, easily patches into the engine harness. Full instructions for both harnesses.
    -Unlocked and tuned PCM
    -Lincolin Continental electric bench seat
    -Custom made aluminum gas tank (cost $1000) with electric fuel pump for the engine.
    -Older True spoke wires
    -Custom aluminum radiator
    -Aftermarket engine mounts
    -Chrome steering column
    -Purple metalflake steering wheel
    Custom engine mounts and trans mount, pinion angle is set correctly and engine is level side to side. Engine mounts are tacked in place but needs to be fully welded. I left it this way incase a buyer wanted to drop in a Ford engine or any earlier V8. I can fully weld out the mounts if you want after a deposit is made.
    Rear 4 link brackets are welded to the diff and 4 link is loosely bolted in.
    I have the imput shaft for the ****** and a stock driveline for the rear end so getting a driveshaft made up will be simple.
    Understand that this is a full project and will need to come apart to be finished. It will need all new gl*** and interior. I would be keeping it but we need the space as I just bought a full custom 53 F100 and I already have another chopped 56 that I daily drive.
    It is currently a roller with no steering column hooked up.Ifront wheels turn and it can be pulled onto a rollback or trailer.
    $12,500 obo
    NO TRADES!
    Has a signed Idaho ***le with matching tag.
    +$1000 if you want a 1956 Mercury M-100 ***le/tag/tailgate with it. The tag and ***le transfer for the Mercury stuff ran us $1400. Mercury stuff will not be sold until the truck is sold.
    Truck is located in Port Orchard, Washington.
    20250426_155425.jpg 20250426_160640.jpg 20250426_160649.jpg 20250425_163407.jpg 20250425_163400.jpg 20250425_163350.jpg 20250425_163311.jpg 20250425_163304.jpg 20250425_163256.jpg 20250414_161236.jpg 20250414_161230.jpg 20250411_185140.jpg 20250411_175816.jpg 20250411_175626.jpg 20250208_124121.jpg 20250208_124110.jpg 20250208_124059.jpg 20250208_124014.jpg 20250208_123946.jpg 20250208_123939.jpg 20250208_123933.jpg 20250208_123929.jpg 20250122_153242.jpg 20250122_153227.jpg 20250122_153113.jpg 20250122_153055.jpg 20250122_153047.jpg 20250122_153038.jpg 20250122_153008.jpg 20250122_152946.jpg
    flyin-t likes this.
  2. 123
    123
    from Seattle
  3. 123
    123
    from Seattle
