Technical CHOPPED 59 Chevy impala
Discussion in 'Traditional Customs' started by rockin rebel, May 30, 2016.
  1. rockin rebel
    rockin rebel
    ok, let's see where this goes..lol I do know how to, and have chopped lots of cars, but now I am thinking of chopping a 59 Pontiac [Impala] 2 door hartop. only concern is of course, the windshield....I have seen lots of pics of cars done, but would like to know what is done for the window..also they still have the tint on top, looking like the gl*** was cut off the bottom ?? thanks
  2. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
  3. 'Mo
    'Mo
  4. alchemy
    alchemy
    The rear window will be worse than the front. Lots of arch that must follow the roofline.
  5. JJK
    JJK
    I think a 59 Impala windshield was used in the Elky which is 2in shorter than a Bel-Air/Biscayne windshield. The roof profile on a 59 Impala is perfect from the factory IMO.
  6. flatford39
    flatford39
    What he said...otherwise it's going to look like ****. You said Impala not El Camino. you can get away with it on the EC but the Impala is a non starter.
  7. mr57
    mr57
    I remember seeing a four door sedan done once that had the front and rear gl*** sunk down into the firewall and rear panel. I "think" the roof might have been halved and a center piece added.
  8. rockin rebel
    rockin rebel
    thanks for the help..I did say I was just thinking..I do like it as is also..
  9. Gotgas
    Gotgas
    from DFW USA
  10. Sauli
    Sauli
    Look up a green '59 Buick LeSabre "Super Sonic" built by a gentleman named David Guymon for Lars Hellgren. Featured in several magazines 15+ yrs ago.
  11. Nailhead Jason
    Nailhead Jason
    Issue #3 of Traditional rod and Kulture has an article about a guy that did just that, chopped a 59 impala. Just happen to have it on my desk at work. It states that he had a custom rear gl*** made and it took 6 different windsheilds cut six different way till he got one that didn't break during cutting. car looks killer, but I cant imagine how much gl*** would cost doing that. I would imagine a 59 impala windshield is not exactly cheap.
  12. _justakid_
    _justakid_
  13. Slopok
    Slopok
    Of course you could always wear goggles!o_O All kidding aside, I thought I read somewhere that Buick or Oldsmobile windshields were somewhat shorter?
  14. flt-blk
    flt-blk
    from IL
    Guymon always cuts the gl*** first and chops the car to match it, just a thought..
  15. Sauli
    Sauli
    ??? Never heard of anyone doing that..?I´ve seen that idea float around this site before, but that sounds like a total hit-or miss approach to chopping anything, frankly.
    My point was, (as seen the build-up pics of this particular Buick), the builder in question didn´t cut Any of the curved gl***, neither the backlite nor the windshield.
    -He started by lowering the roof slightly, and as the bottom mounting point of the "C"-pillar moved forward as a result, he moved the backlite forward, and cut a corresponding amount of material transversely out of the roofskin to allow for the forward transfer of said backlite, while filling in the resulting gap aft of the backlite. The rearmost lower corners of the windshield were sunken slightly into the cowl.
    Anyway, his approach was quite genious, required no cutting of the original curved gl***, and gave the most stylish result very much in theme of the original factory design.
    -Looks like the OP hasn´t posted anything in months, I wonder what the status of the original topic is?
