Projects Chopped And Channeled 1932 Pickup
Discussion in 'The Hokey Ass Message Board' started by DeLuxe 32, Jan 21, 2021.
  1. DeLuxe 32
    DeLuxe 32
    I picked up the top section of a 1000L IBC which fitted the door perfectly. I soaked the door in Citric Acid for a few hours, and gave it a hit with a wire brush every so often. Very pleased with the results.
  2. wheeltramp brian
    wheeltramp brian
    Wow, that works great. How long did it take?
  3. DeLuxe 32
    DeLuxe 32
    It was 5 hrs....I gave it a buzz with a wire wheel on the drill. I then used some deoxidine to prevent flash rust. I will epoxy the inside after a thorough clean and then tackle the new skin.
    I used 1 cup/10 Litres of water.
  4. fleetside66
    fleetside66
    Keep up the good work...it's doable. I remember making a similar bathtub, only with vinegar. I did the p***enger door first, so I could learn when I did the driver's door.
    BigRRR and DeLuxe 32 like this.
  5. fleetside66
    fleetside66
  6. DeLuxe 32
    DeLuxe 32
    A couple of pickups that fit the ***le.... Screenshot_20231001-145619_Instagram.jpg Screenshot_20230429-110948_Instagram.jpg
