Technical Chopped car window gasket
Discussion in 'Traditional Customs' started by lowrodderchev, Apr 6, 2026 at 8:30 PM.
  1. What's everyone doing for the quarter gl*** seal? My 47 Chevy is $200 for both kinda ****s to spends $200 on something im cut up the gl*** will be stationed Screenshot_20260406-182448_OfferUp~2.jpg
  2. Jim Bouchard
    Jim Bouchard
    Set it in a bead of urethane
    My gl*** guy has little rubber blocks of different widths and heights to hold the gl*** off the metal and keep it centered
    lowrodderchev likes this.
  3. 325w
    325w
    How was original gl*** held in place
  4. It sits on slider I'm not to worried about holding in place but more of the seal
  5. theHIGHLANDER
    theHIGHLANDER
    Get the stock seals. Make an aluminum wire template of the opening, TIG wire works well. Once you like it cut the seal to match. There's a Loc***e super glue specific for the job of gluing it back together but I forget the number. I use it for Packard windshield seals that have to be cut and mitered into 1 pc. I'll see if I have some of the glue and give you the number. This way you'll have a chopped window that lives like the OG.
    rod1 and lowrodderchev like this.
  6. It was a slider type setup so both sides had the felt
  7. rdscotty
    rdscotty
    from red deer
    Look at other old cars, or even commercial, agriculture, and RV vehicles to see if you can find something you think may work. Then look at those types of suppliers or the MANY universal profiles that companies like Steele have available and try to match it up. You could also glue the gl*** in like mentioned earlier but use a small universal T or Y shaped molding to finish it off.
    Dennis34 likes this.
  8. theHIGHLANDER
    theHIGHLANDER
    So it's whiskers on both sides? That's easier yet. Still use the template for the shape. Cut a plywood template of the shape and bend straight whisker material to the shape. Some use really small screws, there's clamp-on style clips available too if they were held that way. Doing whiskers is a little bit of a ****, but with rubber backing they indeed seal. Maybe a pic or 3? We like pictures. Stock and what you have? Maybe?
  9. Thank you I was debating on using them like is said the car original had slider rear gl*** but with the chop that's not happening no more
