Not yet, but will be "kind of" eventually... Have a lot of pie cuts and fitting to do... I'm shooting to do something similar to mid 60's-70's Rolls Royces where when you are directly behind them, you cannot see the trunk seam because it is on the side in the quarter crease and tucked down underneath. MA
mark the flow from the roof to the trunk looks good.you must have took these pics at sole tech. i can see wall ride marks in the back ground.by the way what motor are you running in it? jason
yep... that's how we do it as well as seen if I can twist my rearend out from underneath laying rubber......all on our own time of course... Running a .60 over-bit of a cam '54 235 with stock ****** and rearend....
