Chopped Hiboy AA
Discussion in 'The Hokey Ass Message Board' started by Rat.Racer, Mar 22, 2013.
  1. Rat.Racer
    Rat.Racer
    from Maryland
    Does anyone have any pictures of a chopped Model AA hiboy? I like the ride height of the AA without channeling and the look of the exposed frame without running boards, but I heard that chopping a hiboy truck may look weird? What do you think?
  2. HOTRODPRIMER
    HOTRODPRIMER
    I would think that the AA hiboy would look weird! HRP
  3. pdunn10
    pdunn10
    may improve the look if its channeled
  4. HOTRODPRIMER
    HOTRODPRIMER
    I take it you are planing on using the big frame. HRP
  5. sko_ford
    sko_ford
    I.m thinking about useing a AA frame for a 28 rpu but just the frame. They have a 6 inch height just like a 32. But it will get more or less standard running gear & cut to hell
  6. Rat.Racer
    Rat.Racer
    from Maryland
    Do you know of any pictures? I was planning on reusing the AA frame, getting rid of the running boards, or what's left of them (not much), and possibly chopping the top a couple of inches, then adding a wood bed...
  7. Rat.Racer
    Rat.Racer
    from Maryland
    I do have to redo the subrails because the floor is rotted out so that may be an option, I just don't want to drop it too much because I'm 6'2 and I don't want to have to channel the middle of the cab for the transmission. I want as much leg room as possible.
  8. Rat.Racer
    Rat.Racer
    from Maryland
    I'm going to use the frame, and cab and that's pretty much it, unless I can salvage any of the steering or the front axle, but I don't really know what it looks like right now, it's 500 miles away in the middle of the woods under 3' of snow...:(
  9. sko_ford
    sko_ford
    The front axle wont do you much good
  10. HOTRODPRIMER
    HOTRODPRIMER
    If you are 6'2" I can ***ure you that you don't need to chop the top.the model A pickups are small and leg room is a premium,,at your size cutting the top requires yo to lower the seating position and as your **** moves your legs gotta go somewhere and just makes you have to fold up even more.
    If your in your twenty's it's no big deal but as you get a little older and plan on any long hauls it get's real uncomfortable.
    Pictures,I don't have any but the cab is no different than a normal Model A pickup. HRP
  11. MATACONCEPTS
    MATACONCEPTS
    Yeah!!! I see it homie!!!! **** Yeah, you're gonna do it? This is how:
    - 2" 3" at most chop, a subtle chop is very nice.
    - Move the front crossmember back about several inches & mount the perches in the split wishbones & notch the front frame horns & have your axle dropped.
    - raise the spring mounts on the frame to lower the rear or make quarter or ???? . . . .
    - MAYBE pop for a NEW $1500 stock Reg A bed with wood & tailgate& go with a stock 103" wheelbase?
    - Everything else all stock Model AA except with a downdraft 94 carb & intake/header & find like a modern 75 series 20 inch as skinny as you could find maybe 235 tire for the rear.
    - **** it, paint everything all GLOSS BLACK!!!! you could even get away with cans, my coupes grille, frame wheels & suspension is can.
  12. Stevie Nash
    Stevie Nash
    Very true. On a truck you can't move the seat back into the back seat foot area.... I p***ed on an awesome '47 GMC because my knees where in my chest, and there was no room to get any more area.
  13. Rat.Racer
    Rat.Racer
    from Maryland
    Why's that?
  14. Rat.Racer
    Rat.Racer
    from Maryland
    Thanks for the advice! I'll have to keep looking. I am in my twenties, but I realize I won't be forever...
  15. Rat.Racer
    Rat.Racer
    from Maryland
    Thanks, that's a great thread, I subscribed and I'll keep checking back in for more inspiration...
  16. Rat.Racer
    Rat.Racer
    from Maryland
    Thanks for your advice, a lot of great ideas, once I translate them all I'll let you know what I think haha...I had also thought about putting a cast iron tub in the back for the bed...but it was just a thought, don't want to have the scarlet R placed on me.
  17. Rat.Racer
    Rat.Racer
    from Maryland
    Once I get in it and feel it out I can make the determination. That's why I like the hiboy, I don't want to have to crawl into my truck, my back won't like that too much...
  18. sko_ford
    sko_ford
    Its way biger than other axles & there arnt any modern brakes for them
  19. MATACONCEPTS
    MATACONCEPTS
    Go stock
  20. 22 track
    22 track
  21. Rat.Racer
    Rat.Racer
    from Maryland
    Thanks...I'll look into my options.
  22. Rat.Racer
    Rat.Racer
    from Maryland
    By stock do you mean mechanical drum brakes in the front end then disc in the back? What's the traditional way of doing brakes on a traditional rod?
  23. Rat.Racer
    Rat.Racer
    from Maryland
  24. Rat.Racer
    Rat.Racer
    from Maryland
    This is what I'm talking about...Is this considered a hiboy and chopped? Definitely the look I'm going for.
  25. sko_ford
    sko_ford
    Thats deffinately doable. That looks like a regular A frame not AA frame. I say run with your.rails & just use the suspention & parts dudes have been useing for 75 years on A & 32 frames
  26. Rat.Racer
    Rat.Racer
    from Maryland
    I agree...Thanks for the input.
