Chopped Top, the Jimmy Shine way
Discussion in 'The Hokey Ass Message Board' started by Brewton, May 2, 2008.
  1. Brewton
    Brewton
    I've been looking at my new Rod & Custom mag with the article on chopping a top on a Model A coupe (Jimmy Shine's way). I'm just about ready to chop my coupe and I was wondering if anyone has any experience chopping one like Jimmy did. Most of the articles and books I have are doing a straight cut chop instead of the staggered cut. The staggered cut, looks like a slick way to do it. But, before I start marking and cutting - I was looking for some pros and cons to chopping it like Jimmy did.
    Also, how much time should I allow to do this? Is it possible to get it done in one day (I've got several buddies that can help)?
    Thanks,
    Brewton
  2. HomemadeHardtop57
    HomemadeHardtop57
    yea..i checked that article out myself. It really looked nice when the top was layed down after chopping it. And the way they dressed those welds knocked me out..you could barely see the seem. Something else that I thought was a slick idea was that he used blue machinist dye then scribed his cut marks..very cool. A straight chop might be easier for your first attempt. Good luck
    Jerry
  3. Chops
    Chops
    I would never try to rush getting a chop done in just a day, if you've done it before you could probably get it lined out and cut in a day and possibly tacked back in place if you have enough experienced friends helping. But for your first one plan on taking as much time as possible. You know the saying "measure twice, cut once"! I look forward to seeing pics of the work, good luck.
  4. ...isn't it done that way to maintain the correct rear window proportions? one day? take your time and make sure it's done right...maybe one day to lay out your cut lines/tape.
  5. Dreddybear
    Dreddybear
    It's very well thought out. When it comes time for mine, thats how i'm doing it.
  6. HHRdave
    HHRdave
    from So Cal
    Read the article, it's done that way to illiminate distortion and to keep the lines close to stock on the pillars and the keep the curves in proportion on the rear corners.
    It's a good way to chop an A, takes more time and more welding, but has great results.
  7. Brewton
    Brewton
    I read the article. And I understand that it helps with distortion and matching the lines. I guess I didn't ask the correct question - I was just wondering if anyone had any experience chopping a top both ways (staggered and straight cut) and had a preference.
  8. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    I learned that trick from that Ron Fournier chopping and sectioning video. It's nice because when you're O/A welding being off the width of a sharpie is the difference between easy welding with no filler and blowing a bunch of holes. Eastwood sells that dye in a spray can and a metal pick kit to scribe it for like $20...
  9. SinisterCustom
    SinisterCustom
    Or masking tape the width of the chop and spray paint.....tape, spray, remove tape, cut........;)
  10. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    Yeah, I've never chopped a top with it, but it sure is handy for doing patch panels...
  11. Shaggy
    Shaggy
    from Sultan, WA
    It's probably cheaper at a machinest supply talkin about a bombcan of Dyechem right??
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    i got cans of that Dyechem coming out of my machine cabinet..i would rather do the tape and spray method..
    but than i have no chopped roofs yet..so i will quietly go back to my work and STFU:D
  13. Rusty
    Rusty
    That is the way I did the 32. Much better method
  14. Crusty Nut
    Crusty Nut
    I chopped around the back window on my 29 pickup that way. It worked out great. It just did a straight chop on my A sedan and it turned out nice too.
    Here is a shot of my truck.
    m.ralph likes this.
  15. Flea
    Flea
    In that article they also mentioned tacking the top back on then running a saw back through the cut to get a perfect gap. Seems like a good trick but has anyone else done this?
  16. "The Jimmy Shine way"? Does that mean you stand there and gives orders while others do the work? LOL!!!!
    cretin likes this.
  17. EZ
    EZ
    You must be thinking of Boyd Coddington.........may he rest in peace. :D
  18. Maybe you heven't been to the SoCal shop! Think again...Not a slam on the shop,just Jimmy......
  19. HHRdave
    HHRdave
    from So Cal
    No Bob...... it means you have to grease slick your hair back first, get it all perfect and throw some ink on your arms before you chop.....and you get to stop and ask Pete questions if you get lost along the process..
  20. Wildfire
    Wildfire
    It does keep the rear window a little big bigger - making it easier to see. The mail slots look cool too though. Personally, I prefer the large window, keeps it in proportion.
  21. Big Dad
    Big Dad
  22. JimA
    JimA
    Yeah, being the ONLY person with slicked back hair and tattoos would make him REALLY easy to pick out in a crowd at a hot rod event- The last 4 events I went to (Lone Star Roundup, Back to the Beach...) I must have seen him 10,000 times! I suppose I'd have seen him a couple more thousand times if I would have made it to Viva Las Vegas ;)
    If anyone knows a BETTER way to chop a car PLEASE let me know- I can probably help get you in Rod & Custom (they ALWAYS need good tech stories). You must have a saw and welder Bob- let me know when to stop by ;)
  23. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Have any of you ever worked with the man?.......You can not take away the fact that someone really knows his way around a shop and has a great eye for detail.....can you?...Littleman
  24. COOP666
    COOP666
    from Austin TX
    I dig that pickup!
  25. Brewton
    Brewton
    I was just asking for some advice on chopping a top, not a discussion about weather or not you like Jimmy Shine.
    m.ralph likes this.
  26. Brewton
    Brewton
    Forgive the misspelling of whether - Its raining outside.
  27. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    I thought it was an informative how to.......one of many ways to chop a top...and if I had never did one myself that article would have put me out in the garage cutting mine...its all in the pics and text for once and was easy to understand....Littleman
  28. Big Dad
    Big Dad
    My limited experiance ...Measure 10 times as many hours as it will take to do actual cutting :D
    Good luck
  29. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Aww... jealousy is a dreadful diseise...
    ......get well soon.
  30. JimA
    JimA
    From the "Urban Dictionary"-
    1. hateraide- what haters drink.
    2. hateraide- A substance one consumes to alter the path of another whom is in the pursuit to get some from the opposite sex.
