Chopping a 28/29 Model A Radiator Shell....
Discussion in 'The Hokey Ass Message Board' started by bobbyb, Jan 30, 2010.
  1. bobbyb
    bobbyb
    from ohio
    I am planning to channel a Model A body 4". So I would want to also channel the radiator shell 4". Would I say cut 1" out of the shell at 4 different locations from top to bottom, vs cutting out 4" all in one place. My thinking is that less distortion would occur by cutting 1" sections. Am I thinking correctly? :rolleyes:
  2. chaddilac
    chaddilac
    I'd make one cut not 4. you might have to narrow the bottom part to fit back in with the top cause it is narrower at the top if I remember right?
  3. Glen
    Glen
    depending on your setup ....
    I like to cut the sides up a little higher and keep the full size grill shell, that allows the lower part of the grill to go closer to the ground. My car is channeled and the frame is Z'd in the front but I run a stock grill. The top of the grill is still at the correct height to the cowl.
  4. pecker head
    pecker head
    I whacked 4'' out of the middle with no problem on my coop .
  5. Phil1934
    Phil1934
    I cut about 3" in middle of sides and mig welded, then welded up a few weld pinholes. No problem.
