chopping a convet top 1950 cadillac
Discussion in 'The Hokey Ass Message Board' started by Slag Kustom, May 27, 2004.
  1. Slag Kustom
    Slag Kustom
  2. Slag Kustom
    Slag Kustom
    i was also thinking i could move the top foward when i weld it in but i dont want to make the 1/4 windows shorter like most one piece chops
  3. FRITZ
    FRITZ
    Slag,
    If ya buy that top. Im 2 miles from east meadow. if ya need it to be picked up and stored for a while till you can get it just let me know.
    FRITZ
    (516) 409-9551
  4. KCsledz
    KCsledz
    It would be really cool if you bought a hard top convertible setup and had it hide into your trunk. It would be a hell of alot of work but how sharp would that be! [​IMG]
  5. Slag Kustom
    Slag Kustom
    thanks alot fritz that would be a great help. i will give you all call with what i am going to do
  6. 48_HEMI
    48_HEMI
    53 buick you might have to shorten the top [​IMG]
  7. Bob K
    Bob K
    from Antigo Wi.
    Slag
    I just finished my 52 Chev Ragtop, it was a 2dr HT. Found a donor car as you are thinking of doing. IT'S A TON OF WORK. The roof was cut of just about 2 inces below the beltline all the way through the trunk opening. The rear bulkhead between the trunk and back seat has to be replaced also. For the chop the whole top ***embly that fits against the 1/4 panels must have the amount of the chop removed from the bottom. Once it's in there are a thousand things that have to be modified to get it to fold correctly and get the 1/4 windows to operate properly. We are still finding things that don't fit correctly and thats after the top has been installed. If you want to discuss it PM me and I'll give you my phone #.
    B [​IMG] B
  8. RocketDaemon
    RocketDaemon
    from Sweden
    strenghten the body mounths to the frame and do a carson top instead might be a decent idea
  9. FrameDragger
    FrameDragger
    Damn dude, If that is a pic of your ride, you need to fork over the crack pipe! That thing looks way too nice to cut up!
  10. RocketDaemon
    RocketDaemon
    from Sweden
    [ QUOTE ]
    [/ QUOTE ]
    yeah a real good point...
  11. Would the front "Header" of the Buick convert top even be remotely similar to your Cad windshield top shape?
  12. DON_WOW
    DON_WOW
    Put a 62 olds convert frame on a 51 baker last year.Had to narrow the bows 4 inches. Positioned the quarter window in stock location to the body. Made distance from header to first joint( bow over front seat ) 6 inches longer to reach windshield top. No change in the way the side rails fold by changing just front section. Olds header was stright across ,stude has a big V. Split 1 3/4 inch exhaust tubing and welded 4 inches of metal on top curve to make new header. Worked out real nice. Also had to extend back of well so top had room to go down without hitting. Go for it.
  13. cool57
    cool57
    [ QUOTE ]
    [/ QUOTE ]Pics please!
