chrome slots hit on drum weights
Discussion in 'The Hokey Ass Message Board' started by hudsonmand, Aug 28, 2013.
  1. hudsonmand
    hudsonmand
    just wondering what is best way to fix chrome slots hiting on drum weights grind them down,remove them ,or use wheel spacers thanks
  2. weldtoride
    weldtoride
    My 2 cents, and I can't guarantee it, but I think the drum would fit behind the wheel on most of the dynamic spin balancers I have used. If so, I suggest removing the drum weight and balancing the tire/wheel and drum together. Obviously, you need index marks so that the wheel and drum stay in the same relationship on the car.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I would go with the thinnest spacer available like these from Summit...........
    http://www.summitracing.com/parts/joe-38120/overview/
  4. B.A.KING
    B.A.KING
    above^^^^^^^^
  5. Mr48chev
    Thin spacers are available from a lot of sources and probably at you local tire store that installs a lot of custom wheels.
    I'd put a set of matching thickness flat washers on the studs to see exactly what thickness of spacer I needed and go get or order the spacers. Knocking the weights off the drums might seem like the easy way out but it will create a big pain in the *** every time you have to do anything with the wheels and tires on the car from now on out. I would not drive it with the flat washers though, that is just to calculate the thickness of spacer you need.
  6. Depending on how thick a spacer you need and the type of lug nut you are using, you may have to put in longer studs.
  7. Rusty O'Toole
    Rusty O'Toole
    1" bigger wheels.
  8. hudsonmand
    hudsonmand
    thanks for advice
  9. oldolds
    oldolds
    It is old scool to just take them off. Never really had a balance broblem with them removed.
  10. Weasel
    Weasel
    Dynabeads - solves all balancing problems without weights....
  11. jimvette59
    jimvette59
    I had access to a front end shop that balanced the wheels and tires on the car and never had any problems. I would try to find out if there is any old time shops or HAMB member out your way that can do this before grinding the balance weights off. Jim.T.
