Technical Chrysler 6 valves in a Ford flathead
Discussion in 'Traditional Hot Rods' started by Gabe Naccarato, Feb 6, 2025.
  1. Gabe Naccarato
    Gabe Naccarato
    Looking for info on installing Chrysler 6 valves in a flathead ford? I know this was a popular upgrade back in the day. What is involved with the install? Thanks in advance. -Gabe
    turboroadster likes this.
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Are you talking valves from a flathead Mopar six, or from a slant six? Honestly, 1.6 inch exhaust valves from a SBC adapt well to Ford flatheads. An old stock car driver around here told me that he used to put 1.75 inch intake valves from an early Olds V8 in his racing flatheads.
    dan c and Gabe Naccarato like this.
  3. banjorear
    banjorear
    If the stem diameter and overall length check out, can't see why not. That said, valve technology has come a long way. Hi flow SBC valves are about as good as it gets and work great in a flathead.
  4. Bearing Burner
    Bearing Burner
    from W. MA
    I used the Oldsmobile valves on the intakes in the late '60s
    Gabe Naccarato likes this.
  5. Gabe Naccarato
    Gabe Naccarato
    I am following the red book; HOW TO HOP UP FORD & MERCURY V8 ENGINES. It mentioned Desoto 6 valves for the intake of the flathead.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I don't doubt that that was a good idea in 1950, but today there are better choices that are more easily obtained.
    Gabe Naccarato and milwscruffy like this.
  7. dan c
    dan c
    the chevy valves are a bit longer, great for a high-lift cam (400jr, etc).
  8. Smiffy
    Smiffy
    I am aware of Dodge Flathead Six valves being used in a Flathead V8. Back in the late 50's.
  9. The engine cares not what the valves were meant for. Size matters! Head size[ diameter ], stem diameter and length. The performance shop that did the head for my avatar used '
    "generic" valves.
    Ben
