chrysler flathead overheating help!!
Discussion in 'The Hokey Ass Message Board' started by lead54chrysler, Mar 7, 2010.
  1. lead54chrysler
    lead54chrysler
    Iv done every thing but rip the motor apart and she still over heats can anyone give me some pointers? I have a 1954 chrysler with a 265 flatty and it over heats every time I run it if you have any info that can help me throw it my way please!!!
  2. austinsailor
    austinsailor
    You will do best over at p15-d24:
    http://www430.pair.com/p15d24/mopar_forum/forumdisplay.php?f=2
    Possibilities that come to mind:
    water distribution tube falling apart
    Motor block full of sediment
    radiator full of crud.
    Rest of water jacket coated with crud
    blocked hose
    no (or insufficient) water circulation
    What have you done to it?
  3. Dale Fairfax
    Dale Fairfax
    Also retarded spark timing.
  4. blackrat40
    blackrat40
    As mentioned briefly, there is a water distribution tube that runs inside the water
    jacket in the block to carry water to the rear of the block.
    In old engines this tube is frequently mostly rusted away and needs to be replaced.
    Pieces of the rotted tube can also block water flow around the cylinders.
    It is made from sheet metal and a new one can be fashioned by someone with only
    limited metal working skills. Might be the problem
    Good luck pal.
  5. lead54chrysler
    lead54chrysler
    Well if its going to get pricey to fix I'm going to pull the motor and put my 348 chevy in the car but id much rather keep they flatty cuz its to cool
  6. Pull the pump, vanes may have rusted away,,also try to pull the dist. tube to check it and get an idea of what condition the insides look like.
  7. plym_46
    plym_46
    from central NY
    When does it over heat slow speed or high speed. It is unusual for a Mopar system to over heat if the system is in good condition. Simple check on the radiator for proper fllow.
    With the bottom hose removed and the out let blocked, a relaese of water from a non fouled radiator will raise a column of water aproximately 6 inches high when the cap is off and the outlet block is released.
    You may also have a sheared pin on the pump impeller. You do not need to remove the pump to check this. You can check this by removing the heater hose retrun fitting from the top of the water pump, and while stalling the impeller by inserting a screw driver or similar, trying to turn the WP pulley. If it turns and the impeller doesn't move your problem might be there.
    Is it truely overheating or just burping excess fluid after shut down. If you fill the radiator to the top, it will puke out extra coolant leaving an area for expansion. If you keep refilling, it will continue to puke it out. Put in enough to just cover the cooling p***age inlets by about an inch or so.
  8. hkestes
    hkestes
    You might want to try popping out the freeze plugs and then flush the engine the best you can. The lower water p***ages in the block tend to gather gunk over time. With the freeze plugs removed you should be able to flush a lot of the stuff out and open up the circulation.
  9. lead54chrysler
    lead54chrysler
    Now I got the car with the heater core pulled and it was in the box of stuff that was in the trunk would that cause overheating being its not hooked up??
  10. lead54chrysler
    lead54chrysler
    And to answer ur question yes its truley over heating when it gets hot it smokes and steams
  11. 1949P17BC
    1949P17BC
    from Ballwin MO
    Have several flatheads
    1, If it has been sitting for a while, flush the system out (or drain and flush the radiator out for sure, )
    2, Pull the Thermostat
    3. Put a household fan blowing into the radiator and start it up
    4. As it gets hot is the water moving thru the radiator, if not the block is clogged, but before you pullit apart. Shut it off, let it cool, fill it with vinegar, start it back it up, let it sit for a day or two and then pull the radiator, the water pump, water distribution tube and freeze plugs and flsuh it out.
    Its not expensive, its just time consuming.
  12. Frankie47
    Frankie47
    from omaha ne.
    Take the valve covers off and check the block for crud, you probably need to clean the block.
  13. lead54chrysler
    lead54chrysler
    well i dont know off hand where to get freeze plugs or id pull them i found a new head gasket and i am ordering it with my next paycheck and im going to start by tearing it down from top to bottom it hasnt been on the road sence 78 but its been stored inside would any one know where the factory specs on head and what the timeing should be so after im done fixing this i dont run in to more trouble
  14. 73RR
    73RR
    Core plugs are easy. Pull one out and take it to your NAPA/Orielly/or ? store and match it. If the plug you pull is a replacement then it will have the size and part number stamped on it.
  15. pasadenahotrod
    pasadenahotrod
    from Texas
    The water distribution tube is CRITICAL to operating temp of any early Chrysler flathead six or eight. I belive these are being reproduced and should be available from Roberts Motor Parts or Andy Bernbaum both in M***achusetts.
  16. lead54chrysler
    lead54chrysler
    Dose any one know where I can get a gaskit kit for the motor??
  17. 41 C28
    41 C28
    NAPA............
    Gasket kit $51.89 as per the web site.
  18. lead54chrysler
    lead54chrysler
    Gaskit set is on the way would anyone know the tuq specs for the head on this old mopar?
  19. I've got one of those. Have got a factory shop manual, too. Will try to PM you with some specs. Am dealing with a family member in a nursing home so if i get sidetracked, please PM me a reminder. Good advice here, these are tough old engines:cool:.
  20. RodStRace
    RodStRace
    Yep, water distribution tube and dist. advance.
    Clean out the p***ages, but don't flush the junk into the radiator!
  21. Crestliner
    Crestliner
    I have some NOS water distributions tubes. Yours must be a six, wasn't all 8s hemis in 54?
    If I have a tube for yours 20.00 + the ride.
  22. lead54chrysler
    lead54chrysler
    well i still am unable to find a water distribution tube to have on hand im getting all the parts i need so when i tear the motor down i can do every thing in a day this tube is located in the block right?? and while i have the whole thing apart im am going to make a new intake for it to run 1 or 2 holly94s im not sure yet but the little on shooter has to go. if anyone has split exaust for a motor like this that would be killer if not i may make my own
  23. lead54chrysler
    lead54chrysler
    freeze plugs have not been an easy find eather iv found some in the right size but there too deep of a dish compared to the stock ones
  24. Mark Karger
    Mark Karger
    from houston TX
    Langdon's Stovebolt has 2 pc. cast iron headers for flat Plymouths & Dodges. It is rather expensive at $350.
  25. hkestes
    hkestes
    Water Distribution Tubes and Freeze Plugs are available from Andy Bernbaum http://www.oldmoparts.com/l.htm
    Not having your heater core in should not be an issue as many of the engines originally had a valve at the rear of the head to shut water flow off to the heater during summer.
    I will get out my manual and get the torque specs for the head this evening and post it for you. While your engine is most likely the 25 inch block and mine is the 23 inch block the torqe specs should be much the same.
    There are lots of Shop Manuals on Ebay at reasonable prices and I would say if you are going to do any major work on your car you should drop $30 on one of these as they are invaluable.
  26. lead54chrysler
    lead54chrysler
    well i got gaskets and freeze plugs and mr. crestline had a water tube so i think i got ever thing but the tuq specs so im hopeing next week when the weathers nice to have her all fixed and ready one last thing tho would and one know were there are some tail lights that are in good shape???
  27. hkestes
    hkestes
    Here is the page from my shop manual showing the torque specs from the 23 inch block. Yours should be the same I would think even though it is the 25 inch block. Sorry if it is a big image just wanted to make sure you could read it.
  28. lead54chrysler
    lead54chrysler
    How man ft-lbs should they be tqr to??
  29. RodStRace
    RodStRace
  30. Country Gent
    Country Gent
    WATER DISTRIBUTION TUBE!!!. Recently I posted a question on ??????? "HOW THE HELL DO YOU GET ONE OF THOSE OLD *******S OUT OF THE BLOCK.??????? May have to do it on my 47 pickup
    UPDATE;
    THANK YOU RODSTRACE!! Just went to the P15-D24 link and got the info I was looking for. What a great place to get educated
